ECU + Butterflies = Confused
I'm looking for an OBD1 ECU (which I want to chip and run uberdata on) that will be able to control the secondary butterflies on an h23 intake manifold. I bought a p06, but was told that it might not be able to control them. Any ideas? If I can convert the p06 to control the butterflies, I'll do that, but what other ECU will control them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95AccordVtec »</TD></TR><TR><TD CLASS="quote">do you know where I can get instructions on converting a p75 to a p72? pgmfi forums are down ...</TD></TR></TABLE>
i don't think you can convert a p75 to a p72...that's like buying a p28 and making it a p13...
expletive it, u already got the p06, if it cant control the iab's just connect the wire to a switch/button and open them as you please, or u could just connect it to the vtec solenoid wire so it opens with vtec, which is only a few hundred rpms later than the ecu would open them
God damn it. I had a thread just like this 2 days ago, but it's been deleted. Anyway, it left off with someone saying I should use a P75 (94/95 LS), but would that open the secondary butterflies? What about the PR4 (90-93 LS)?
Sent an email to phearable.net
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Right now, I've got an H23, and I plan on using either a P75 or PR4 ECU (since you can't chip a P14). Do you know which, if either, will have IAB control? If neither, which ECU will control IABs and work with an H23?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">You could use a p75 and add iab support, we do not offer that service at this time.
Thanks,
John Vega - Phearable.net</TD></TR></TABLE>
Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">ehhh....my bad...</TD></TR></TABLE>
YOU SUCK!
YOU SUCK!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">Any other opinions. I know the P72 has IAB control, but does a P75?</TD></TR></TABLE>
A P75 doesn't have vtec or IAB control, but you can add them and basically have a P72 without the knock board.
finest_GSR
Oct 3, 2006 06:45 PM
danmanh22
Mar 28, 2004 07:05 AM
