sqeaky clutch pedal..
Old Apr 9, 2002 | 11:41 AM
navin's Avatar
Default sqeaky clutch pedal..
Alright this problem just started today morning - I took the car out and when i push the clutch pedal in i get a little noise, but when coming out i hear the squeak. Any sort of signs I should look so i can solve this problem??
Facts- 1994 VX Motor, just bought from old owner, supposed new clutch (which sucks), and about 170,000 miles on it...
maybe this will give me an excuse to put my new motor in
Old Apr 9, 2002 | 12:36 PM
John's Avatar
New User
Default Re: sqeaky clutch pedal.. (navin)
You probably need only lube up the clutch pedal spring...
Old Apr 9, 2002 | 01:03 PM
G_S_R's Avatar
Default Re: sqeaky clutch pedal.. (DunReit)
yup.
Ron
Old Apr 9, 2002 | 02:22 PM
fixhondas's Avatar
and maybe the clutch release arm needs lubed- do you hear the noise inside or outside the car?
Old Apr 9, 2002 | 03:32 PM
navin's Avatar
Default Re: sqeaky clutch pedal.. (fixhondas)
inside the car - but i think also from the outside too when i depress the clutch. Where can i locate the clutch spring thingy bobber - sorry forgot the exact term
Old Apr 9, 2002 | 06:38 PM
hioctane3's Avatar
Mine did the same thing, and it was the clutch release arm. I just sprayed it down with some wd40 and it went away. BTW if the noise is coming from the engine bay than it is most likely the release arm.
H22Apexi
Jun 5, 2003 01:04 PM
rockwilda
Jun 19, 2002 03:57 PM
Honda F1
Apr 24, 2002 05:37 PM
95TEG
Mar 7, 2002 10:09 AM
