Anyone with a ball joint camber kit installed? Problems?
Does anyone have an Ingalls or SPC front ball joint camber kit installed on a 94-97 accord that's lowered 1.5" or more?
Im running -1.8 and -1.9 degrees in the front after neuspeed sport springs and need to get it fixed.
My biggest question is do you have problems with the upper control arm banging the inner fender now with the kit installed?
Is the ball joint kit the best option for the 94-97 accords?
Does anyone know where I could find the required bolt spec for the rear "washer trick"? Can I get these bolts commercially, or do I need to order them special?
Thanks!
Thanks!
I have a 6th gen, and I have it lowered 2.25", and am using the ingalls kit, however, most of my buddies warned me not to get the ball joint alone, but the entire control arm with adjustable ball joint, because there is little to no room when you lower an accord(on 6th gens98-01 for sure, not to certain for other gens) in the suspension area, and fender rubbing and control arm issues are number one, as for the bolts you might have to special them..
russianswty
Mar 9, 2007 10:26 PM
DaChoZn1
May 15, 2005 07:57 PM
