dc5 k24 running problems please help
Old May 1, 2006 | 02:36 AM
94_vteckiller's Avatar
Default dc5 k24 running problems please help
I put the crv k24 with the 2002 k20 type s head in my base line dc5 I have k pro and its telling that i have 98% open throttle and its only when the power is just on in the car its also saying it over heating and we pop the raidtor cap and its still cold???
Old May 1, 2006 | 03:26 PM
NEED HELP BUMP IT
Old May 2, 2006 | 12:08 PM
6SPD_EK's Avatar
Default Re: dc5 k24 running problems please help (94_vteckiller)
what engine harness are you using? looks like you are having problems with TPS (throttle position sensor) & temp sensor located on block - or a connection with those
post this up on http://www.k20a.org there are a bunch of franks running there
Old May 2, 2006 | 06:25 PM
scmil95eg's Avatar
* don't know or sure, i've never tried this with a honda - but with a gm tps, if you swap the #1 & #3 pins on the tps, you reverse it's rotation. i get this quite a bit with small block chev's. easy enough, worth a try. good luck.
Old May 3, 2006 | 05:24 PM
it was the pins thanks guy for the info
ryanhauk
17
Jan 24, 2010 12:35 AM
pleej
Oct 14, 2009 10:25 AM
si90rex
Mar 30, 2006 12:54 PM
crxdriver89
Aug 8, 2005 08:20 PM
stizzit
Jan 24, 2002 08:30 AM
