removing butterflies on GSR manifold...Good or BAD?
Old May 1, 2006 | 12:42 AM
redracer1024's Avatar
Default removing butterflies on GSR manifold...Good or BAD?
will removing the secondary butterflies in the GSR intake manifold help or hurt performance?
Old May 1, 2006 | 12:47 AM
SlamminS85's Avatar
Default Re: removing butterflies on GSR manifold...Good or BAD? (redracer1024)
bad, screw up your air fuel ratio, VTEC engages, then butterflies open about 1000 rpm later...
Old May 1, 2006 | 03:32 AM
tomlinson619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redracer1024 &raquo;</TD></TR><TR><TD CLASS="quote">will removing the secondary butterflies in the GSR intake manifold help or hurt performance?</TD></TR></TABLE>
it will hurt your performance.. you will lose low end torque.. the butterflies actually help on a stock motor.. giving more mlow end, midrange, and high end too as it opens.. the only way i can think of removing it is if u have bigger cams.. because bigger cams need more breathing
Iloveyourhonda92
Nov 20, 2010 07:01 PM
abusedvtec
Mar 15, 2008 07:34 AM
silentkill03
Jun 22, 2005 08:21 PM
blacK_Dc4
Feb 23, 2005 08:07 AM
hybrider
Apr 9, 2003 09:20 AM
