Stipped bolt holes (helicoil or tap).....
Old Apr 9, 2002 | 11:04 AM
therealciviczc's Avatar
Default Stipped bolt holes (helicoil or tap).....
I took the trans mount off of the trans that was on my G/F's civic, and one of the bolts was cross threaded bad from the factory from what I can tell. Needless to say, after coming in and out of my car a few times, it's completely stripped. Can this be fixed with one of those heli-coil things that I've personally never seen but always hear about? Should I just drill it and tap it for an 18 mil instead of a 17 mil?
How good do those helicoils work?
This is on the rear mount of a D series trans (goes down through the top).
Thanks in advance.
Old Apr 9, 2002 | 06:43 PM
B16ED4G's Avatar
Default Re: Stipped bolt holes (helicoil or tap)..... (therealciviczc)
if room permits I would use a helicoil, the problem I've had with taps and aluminum
is if you don't redrill the hole big enough, the aluminum can crack. theyn your really screwed.
just my opinion
Chris
EfSedanLove
20
Jan 25, 2010 07:51 PM
sol_1
Aug 11, 2008 05:21 PM
tree fingers
Jul 27, 2008 08:13 PM
Mr.Meowsome
Dec 1, 2006 11:27 AM
Crx2092
Nov 19, 2004 11:23 AM
