air from climate control vents smells
i noticed that when i have the fan blowing with or without the a/c on, the air coming from the vents doesn't smell too great. Is there some way i can flush this odor out? or if there is a part i can replace to make it at least odorless air coming out of the vents? any information will be most helpful. thanks
4th gen 93 lude Si. is there any parts i can disassemble and try to manually clean out? i'm assuming 4th gens don't have any cabin filters.
nope they sure don't. umm not really. there is an intake vent near your windshield wipers, might want to check there
other than that, you could always dump an air freshner or colonge into the vent
actually there is a deoderizer you can spray into your ac lines that takes away that smell. lemme find the site that sells it and ill post it up
cant seem to find the one that hooks up to the lines just like when you charge the system but i found these. hope this helps ill keep looking.
http://www.keep-it-kool.com/treat/treatment.html
http://store.lenzdist.com/search.php?xSearch=odor
