camber kit for 98 base lude
Old Apr 9, 2002 | 10:54 AM
spangler's Avatar
Default camber kit for 98 base lude
i need camber kit cause im putting 17s on and droping it
do you think i need a camber kit??? i dont wanna have to spend an arm and a leg for tires
Old Apr 9, 2002 | 11:15 AM
Smurfylude's Avatar
Default Re: camber kit for 98 base lude (spangler)
not unless your going to drop it more than 2.5 inches....
Old Apr 9, 2002 | 11:58 AM
Anubyss's Avatar
How much are you lowering by? I would say anywhere near a 2.0" drop and you may need a camber kit. It's hard to say with any certainty since everyone seems a little different. I had a 1.4" drop and needed a kit for the rear. I had them aligned after the drop and noticed the rear was 1.9 for camber. Hence the kit.
You may be able to get away with it but then again maybe not. It is of course cheaper to get it drop and the camber kit done at the same time. But I would say most people are safe with up to 1.5" drop without a camber kit.
Old Apr 9, 2002 | 04:51 PM
LudeLC's Avatar
New User
Default Re: (Anubyss)
I agree that you are more likely to need one for the rear than the front, and that up to 1.5" of drop will probably not be a probem. Farther than that......
Old Apr 9, 2002 | 07:17 PM
Buckkaaaa!!'s Avatar
New User
Default Re: (LudeLC)
you can compensate for a little of it with a tiny bit of toe
Old Apr 10, 2002 | 08:32 AM
bigwei's Avatar
I think you need a camber kit no matter how low you drop your car. It'll save you money in the long run on tires. That's just my opinion.
Old Apr 10, 2002 | 09:01 AM
spangler's Avatar
ok im gonna go ahead and get the camber kit for front and rear i have some more questions who makes the best kit for front and rear and how much do they run
Old Apr 10, 2002 | 09:38 AM
Anubyss's Avatar
I have Progress fronts and Ingalls rears. It was around $150 from what I can remember. There was an issue with the Ingalls front kits so I got the Progress kit for the front. They have a new kit out now I believe so everything is probably different now.
http://www.importstop.net/ingallsgroupbuy.htm
That is $150 per kit and not for both front and rear kits. Just wanted to clarify....
[Modified by Anubyss, 2:20 PM 4/10/2002]
Old Apr 10, 2002 | 09:52 AM
spangler's Avatar
cool thanks i will have to put an order in today
JTaudio0212
Honda Civic (2006 - 2015)
18
Oct 25, 2007 04:58 PM
JDMPLEASE
Honda Civic (2001 - 2005)
25
Sep 3, 2007 05:51 AM
94RedEGCoupe
Jul 4, 2004 08:33 PM
tonezilla
Mar 28, 2004 06:50 AM
The Internet Tough Guy
34
Oct 10, 2003 10:32 AM
