Suspension & Brakes Theory, alignment, spring rates....
gc's what shocks?
Old Apr 30, 2006 | 08:31 PM
alex_s817's Avatar
Default gc's what shocks?
i know that this question is always asked but i cant find a real answer. i have ground controls on stock shocks on my integra. i need new shocks badly and i know koni yellows are one of the best set-ups. i thought i could just put my coil overs on the konis, but ive heard that a seperate peice is required because the sleeve is too big around. what should i do? sell me gc's and get full coilovers? or buy any other type of aftermarket shock that will fit with my gcs. if i get another kind of aftermarket shock, what should i go with? sry so long and thanks for any help and responses
Old Apr 30, 2006 | 09:59 PM
Voyage34's Avatar
Default Re: gc's what shocks? (alex_s817)
the koni shock bodies do have a differnt diameter, so they require a differently sized sleeve from ground control.
depending on your purposes with the car, upgrading to a good quality should would probably be my recommendation. the tokico illuminas have the same diameter body as stock so you can use the GC setup you alread have. they arent up to par with say koni yellows but as many here will attest, are a very good quality shock, especially when they can be found for ~350 shipped via ebay. they also carry lifetime warranty, which is always a plus.
if you choose to sell your current kit to buy the koni/gc setup im sure you wont be disappointed with that route either. more than likely it will end up the same cost if not cheaper than a full coilover setup, with better quality shocks, higher range of adjustment and lifetime warranty on all pieces- the konis the eibach springs, the GC sleeves, the whole lot
Old May 1, 2006 | 05:08 AM
alex_s817's Avatar
Default Re: gc's what shocks? (Voyage34)
ok thanks , anyone else have similar opinions? also is there a way to use my ground control sleeve or do i have to replace it to use koni yellows?
also if i have to sell , how much do you guys thihnk i coiuld get for them, they are in very good shape.
Old May 1, 2006 | 09:11 AM
94eg!'s Avatar
#1 Super Guy
Loved
Search in the classifieds to see how much used sleeves sell for...
There is no way to use your old sleeves safely. The Koni shock has a totaly different spring mounting system that cannot sit a sleeve on it. You have to get the special sleeves that eliminate the original Koni spring perches all together...
When I switched to Koni shocks (I already had GCs), I had to purchase new threaded sleeves, and new gold nuts to make everything work. I just reused my GC springs because I liked the rates. The cost was over $100 dollars for the parts. You could easily sell your old sleeves/nuts/spacers & make a bit of that money back...
Old May 2, 2006 | 07:29 PM
alex_s817's Avatar
Default Re: gc's what shocks? (94eg!)
hey 94eg, i was just wondering what spring rate you are going with on the eibachs?
Old May 2, 2006 | 08:22 PM
94eg!'s Avatar
#1 Super Guy
Loved
400f/250r and the car is a 94 CX lowered 3" on 205/40/16. The car is for street use only...
Old May 3, 2006 | 05:27 AM
alex_s817's Avatar
i see.., mine in the back seem really soft, and the writing on the spring is gone so i cant tell the spring rate. do you think if the rear shocks were blown, it would compress as easily as it does?
Old May 3, 2006 | 07:09 AM
94eg!'s Avatar
#1 Super Guy
Loved
Usually when they are "blown", shocks will have fluid running down the sides. It's hard to tell if they are blown by pushing them because the valving is speed sensitive. It is definently possible. Mabey someone else can give their opinion...
kevinm1981
Suspension & Brakes
10
Jul 12, 2009 01:13 PM
doubleshotz
Suspension & Brakes
21
Oct 5, 2007 02:55 PM
zeRozeRo L$
Suspension & Brakes
12
Apr 6, 2006 03:48 PM
tegrunner
Suspension & Brakes
Jun 11, 2005 08:54 AM
asianridr
Apr 10, 2002 09:50 PM
