crx shock compatibility
i have a 91 crx hf with 93 integra suspension and disk brakes all around with type r rear lower control arms(these mount up with eye mount shock bottoms). i've been searching for some aftermarket shocks new online and used on hmarket. i noticed online they sell shocks for "Civic/CRX 88 & Integra Type R"
link:
http://froogle.google.com/froo...hl=en
scroll to bottom on link
does this mean that i can use type r shocks on my car if so what years. any help would be greatly appreciated. thanks everyone
link:
you can use the type r shocks but they will be slightly longer so it'll make your car higher. i suggest using the 88 rear shocks myself
edit- mah bad, guess they are the same thought they weren't
Modified by RexQ at 12:37 AM 5/17/2006
The Integra Type R rear shocks are the same length and mounting as the '88 CRX rears. The spring perch is the same and the location is within about 3 mm so it is functionally the same shock.
