Kosei 16x7.5..43+ offset w/ 215/50 good on 5th gen? A very low one..
Old Apr 30, 2006 | 07:52 PM
Halo's Avatar
Default Kosei 16x7.5..43+ offset w/ 215/50 good on 5th gen? A very low one..
Picking up a set of coilovers shortly and am looking into getting wheels..I am looking at the Kosei K1's 16x7.5, 43+ offset and 215/50 tires..Has anyone run this size? Looking for something that doesn't rub ..
Old May 1, 2006 | 08:10 AM
Halo's Avatar
Default Re: Kosei 16x7.5..43+ offset w/ 215/50 good on 5th gen? A very low one.. (Halo)
nobody is running 16x7.5?
Old May 1, 2006 | 01:31 PM
HxClude's Avatar
You want 225/45/16 for that wheel - dead on right size and best (largest) contact patch. 215/45/16 would be an ok substitute but is a little smaller than stock diameter. 215/50/16 is Why get a taller sidewall than stock? 225/45/16 has plenty of sidewall (same as stock) and its significantly wider
If you're really low you might rub a little in the rear with 225/45/16 but probably not too bad. If you have more of a race setup with very stiff springs you're golden though. I would imagine since you're getting K1s, you're not building a show car and planning on dropping it to the ground.
zc_eg6
Jan 9, 2009 03:38 PM
smackdown
Feb 8, 2007 02:57 AM
Type Ek
Sep 26, 2006 08:14 PM
Dgilmour
Apr 29, 2006 03:49 PM
02 coupe
16
Aug 27, 2002 03:12 PM
