hondata intake mainfold gasket
Old Apr 30, 2006 | 06:09 PM
tegdude227's Avatar
Default hondata intake mainfold gasket
wat do you guys think is it worth the 50 bucks i would be spending ? do any one have any experience with it ? and i have a blox mainifold if i got this gasket would i need to get longer head studs for this ? and just leave some of your input ?
thanx
Old Apr 30, 2006 | 06:10 PM
IntegraGSR23's Avatar
Default Re: hondata intake mainfold gasket (tegdude227)
Well worth it
Old Apr 30, 2006 | 06:23 PM
tegdude227's Avatar
Default Re: hondata intake mainfold gasket (IntegraGSR23)
but am i going to need to get longer head studs for the mainifold to fit on there ?
Old Apr 30, 2006 | 08:29 PM
Robstunner4's Avatar
when i got mine IM and profab gasket, i took the headstuds out and just used hex cap screws. make sure u use yellow zinc.
i paid $30 for the profab gasket. same thing
Old Apr 30, 2006 | 09:24 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Yeah its worth it, if you check out hondata's website they have the actuall test results and the temp reduction to the manifold was pretty substantial.
In case anyone doesnt know its supposed to not allow as much heat to transfer from the head to the manifold, decreasing air inlet temps.
Old Apr 30, 2006 | 09:32 PM
Akalima's Avatar
Default Re: hondata intake mainfold gasket (ForceFed_Motorsports)
I have a hondata gasket its a good by. and i jsut got my longer studs from the shop. As for the hex heads they suck *** always comin lose the dont have enough surface area to stay tight. i changed all mine out.
Old Apr 30, 2006 | 09:54 PM
nos junkie's Avatar
Default Re: hondata intake mainfold gasket (Akalima)
Old Apr 30, 2006 | 10:15 PM
aeon's Avatar
the only difference i see between the expensive thermal gaskets and the cheaper ones is the qaulity.. i bought a passwordjdm one for about 45 and it came out smooth and great. I bought another one from one of our sponsers and one side was smooth but the other side had a rough edge. I just sanded down the edges a little and everything was fine. also, the fit wasn't as perfect as the password jdm one.
I remember seeign somehwere that the hondata one provides thermal washers with their gasket.
Old May 1, 2006 | 03:24 AM
tegdude227's Avatar
Default Re: (aeon)
well were can i get longer studs at ?
Old May 1, 2006 | 07:55 AM
Akalima's Avatar
Default Re: (tegdude227)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 &raquo;</TD></TR><TR><TD CLASS="quote">well were can i get longer studs at ?</TD></TR></TABLE>
Just find the length and pitch of the bolts u have know and go to a home depot or a bolt supply warehouse and by like a 1/4 longer bolts. They dont have to be honda bolts as long as there the same type of bolt. But have fun taking off ur intake manifold sucks ***
98bucket
Nov 28, 2010 08:18 AM
LudeAchris2001
May 3, 2006 09:43 PM
GSR4U2NV
11
May 22, 2005 08:04 PM
Houston Hatchback
20
Feb 18, 2004 08:57 PM
EG3-R
Aug 29, 2002 04:09 AM
