Going All Motor and Im bone stock
Old Apr 30, 2006 | 05:42 PM
EP3H's Avatar
Default Going All Motor and Im bone stock
My Goals:
to put down 200whp or more
streetable
what i know and want to run:
stage 2 cams (crower)
crower cam gears
smsp or rmf header
new pistons and rods(which ones are good?)
i know im going to have to run a whole new valvetrain as well
valve springs, retainers and valves them selves
what else do i need ?
what size ehxaust
what should i get done to the block to make it stronger?
i assume the head will only need a port and polish but any other suggestions would help
tranny wise, what would be better?
would a h23 be better than my h22 tranny?
what computer do i need to run a high compresion setup?
is there anything else that im missing?
im sorry if im repeating any other thread, im just frustrated and need some tlc.
thanks in advance
Old Apr 30, 2006 | 06:33 PM
mgags7's Avatar
there is no reason to get cams and pistons if all you want is 200whp
easy formula for that:
3" intake pipe, prototype racing velocity stack
70mm throttle body portmatched to IM
rmf header, 2.5 inch exhaust
tuned on a p72 ecu with any ems of your choice (hondata, crome, etc...)
done
Old Apr 30, 2006 | 06:49 PM
helicopter201's Avatar
Default Re: (mgags7)
knows his stuff.
recommend a custom magnaflow from kteller.
2.5" SS piping, 2.5" carsound cat, 2 magnaflow 2.5" x 14"L SS resonators, 2.5" inlet magnaflow muffler w/kteller custom dual tips
ps are crower stage 2's best for low/mid rpms or are the stage 3's more tuned for that?
Modified by helicopter201 at 8:00 PM 4/30/2006
Old Apr 30, 2006 | 06:52 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">there is no reason to get cams and pistons if all you want is 200whp
done</TD></TR></TABLE>
depends on the dyno
Old Apr 30, 2006 | 07:01 PM
mgags7's Avatar
NO MORE OF THAT DAMMITTTTTTTT!!!!
Old Apr 30, 2006 | 07:08 PM
RyosukeFC3s's Avatar
Default Re: Going All Motor and Im bone stock (PenguinHerderBB6)
What would I need to do to get 250whp?
Right now I have DC header, test pipe, Espelir Exhaust, and AEM CAI.
I plan on ordering the Euro-R IM, but I dunno what TB to get with it. Gonna go with a P72 Hondata. Type S pistons and rods, crower stg 3 cams or possibly the Type S cams
Old Apr 30, 2006 | 07:09 PM
98vtec's Avatar
moderator emeritus
Default Re: Going All Motor and Im bone stock (RyosukeFC3s)
completely built, JUN III's at the least, custom header, custom IM or ITB's
Old Apr 30, 2006 | 07:28 PM
EP3H's Avatar
i forgot to mention i have a burnt valve andi am going to tear down the motor. lets put it this way i want to gain as much power out of my motor with an all motor setup. so, in saying that, what are my options for building the block .
Old Apr 30, 2006 | 07:54 PM
InvaderTrax's Avatar
While you've got the head off, P&P, new valve springs, titanium retainers, and cams of your choice. Unless you plan to tear apart the bottom end as well, just clean your pistons with steel wool (if they're dirty, which they probably are)
Old Apr 30, 2006 | 08:25 PM
EP3H's Avatar
get the im port matched to the tb????
Old Apr 30, 2006 | 10:02 PM
98vtec's Avatar
moderator emeritus
Default Re: (PenguinHerderBB6)
http://www.pocketrocketsracing.com - Talk to Frank
http://www.rlzengineering.com - Talk to Brad
http://www.importbuilders.com - Talk to Jeff
Old May 1, 2006 | 05:18 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PenguinHerderBB6 &raquo;</TD></TR><TR><TD CLASS="quote">70mm throttle body portmatched to IM
get the im port matched to the tb????</TD></TR></TABLE>
yes get it portmatched, or else you will have a 4mm lip around the whole way, no good for flow......
TnC
22
Feb 2, 2011 12:39 AM
h22prelude99
37
Aug 17, 2010 05:57 PM
music462
Sep 1, 2008 11:19 AM
tyflip2
Nov 11, 2003 07:47 PM
92lSilude
12
Oct 26, 2003 05:58 AM
