act pressure plate devloping surface rust from sitting while project gets underway what to do?
Old Apr 30, 2006 | 04:47 PM
b18sihatch's Avatar
Default act pressure plate devloping surface rust from sitting while project gets underway what to do?
ok so i took a look at my act xtreme pressure plate today and it is devloping surface rust on the clutch forks mainly on the underside of the fingers , but there isnjt any rust on the clutch disc surface where the disc sits, its fine.... is any of this rust going to effect anything or should i have it sandblasted? need to know cos my project is coming underway quick
Old May 1, 2006 | 05:09 AM
b18sihatch's Avatar
Default Re: act pressure plate devloping surface rust from sitting while project gets underway what to do? (
anyone else have this problem
Old May 1, 2006 | 11:22 AM
91DA9's Avatar
I am not positive on this, but it should not be a problem, they are going to get more messy when the friction material from the clutch starts sticking to it. As long as the rust is only surface it shouldn't be a problem.
Old May 1, 2006 | 02:04 PM
Runnerdown's Avatar
a little bit of surface rust is no big deal. take a rag and some wd40 to remove it and prevent more from starting.
whiskaz
Dec 16, 2006 01:55 PM
teknohatchie91
Nov 28, 2004 07:54 PM
yellowturbo
Sep 20, 2004 12:10 PM
MrEg
Sep 17, 2003 04:59 PM
GraphiteAccord
Feb 12, 2003 10:56 AM
