FS: Fully Built b18b Eagle Rods, Eagle Crank, Ross 9.5:1 Racing Pistons, and More
Old Apr 30, 2006 | 03:59 PM
wushubrian's Avatar
Default FS: Fully Built b18b Eagle Rods, Eagle Crank, Ross 9.5:1 Racing Pistons, and More
Hey hows it going. Basically I was planning on building a b18b to run a 125 shot of nos. So heres what I'm selling a fully running stock b18b from a 96 integra ls. Comes with everything. It is a full swap. Has a new xtd stage 3 clutch in it with an xtd 8lb flywheel. Plus along with the engine I'm including the following: Eagle Rods, Eagle Crank, Ross Racing Pistons for Turbo/NOS and rings. Also I'm including skunk2 intake manifold, holley 70mm throttle body. Also I'm including the NOS's direct port 4 fogger nitrous system. I'm asking 3,300 for the whole setup. All the parts are brand new in Box. I basically was building the car for drag but I'm running out of money and would rather just buy a stock ITR swap. This setup when put together even with a stock head should put down 300 hp. Holley says that there 125 direct shot should give me an extra 220 hp. You have everything to build the bottom end. I was planning on also building the head with all crower products. I'm asking $3,300 for the whole setup.
Old Apr 30, 2006 | 04:20 PM
wushubrian's Avatar
Default Re: FS: Fully Built b18b Eagle Rods, Eagle Crank, Ross 9.5:1 Racing Pistons, and More (wushubrian)
ttt
Old Apr 30, 2006 | 04:54 PM
wushubrian's Avatar
Willing to Trade for an ITR SWAP
Old May 1, 2006 | 08:04 AM
wushubrian's Avatar
up
Old May 2, 2006 | 09:01 AM
wushubrian's Avatar
ttt
Old Jun 12, 2006 | 01:35 PM
cuin9sec
Guest
Posts: n/a
pm'ed...thanks!
Old Aug 28, 2006 | 08:07 PM
Muckman's Avatar
Moderator in Chief
Default Re: FS: Fully Built b18b Eagle Rods, Eagle Crank, Ross 9.5:1 Racing Pistons, and More (cuin9sec)
I want that Eagle crank. Part it out?
sik_sol
Dec 29, 2006 08:06 AM
crazzeboost
May 17, 2004 01:17 AM
