Quick K-Series Question
Old Apr 30, 2006 | 03:05 PM
AMG's Avatar
AMG
Default Quick K-Series Question
Plans for swapping the k-series motor are starting to unfold and I just had a quick question.
The axels will obviously not work with the new motor and hasport offers axels specifically for the k-series into the dc chasis. My question is this: Their level 1 axel is rated to handle up to 200whp. Should I really worry about upgrading to level 2 (400whp) if I am going n/a and hopefully putting down 220whp or so?
Just wondering b/c I couldnt see the stock axels handleing anymore then an aftermarket axle and the stock seem to do just fine with applications under 250whp.
Thanks
Old Apr 30, 2006 | 06:01 PM
efi2nr's Avatar
From: Home of the fastest Hondas in the 417 area since, 1997, usa
Default Re: Quick K-Series Question (_HondAddicT_)
do not buy the stage 1 or 2 axles. The stock ones are stronger. You need to use the stock K axles with B outer or stock K axles with the K outers and Circuitworx hubs. I run that last combo in my car and I pull 1.6 60fts all day. You can do the same in your DC
Old Apr 30, 2006 | 06:02 PM
efi2nr's Avatar
Default Re: Quick K-Series Question (efi2nr)
PS I make well over 250fwhp allmotor
Old Apr 30, 2006 | 06:49 PM
chameleon's Avatar
word, base rsx and ep3 work as well.
Old Apr 30, 2006 | 08:21 PM
AMG's Avatar
AMG
Default Re: Quick K-Series Question (chameleon)
Thanks guys. Appreciate the info
Old May 1, 2006 | 03:54 AM
johnnysample's Avatar
hybrid racing makes them as well ..... i honestly have been using straight up b series axles, and havent had one problem with them YET
Old May 1, 2006 | 01:29 PM
AMG's Avatar
AMG
Default Re: (johnnysample)
Wow Interesting. Havent heard anyone using straight b-axles yet.
Any pics?
Old May 1, 2006 | 01:31 PM
AMG's Avatar
AMG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">word, base rsx and ep3 work as well.</TD></TR></TABLE>
Any difference in the S vs. Base model axels?
Old May 1, 2006 | 02:09 PM
djmota's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _HondAddicT_ &raquo;</TD></TR><TR><TD CLASS="quote">
Any difference in the S vs. Base model axels?</TD></TR></TABLE>
the outer splines and ends are abit beefier on the s
Old May 1, 2006 | 03:31 PM
EK9-Stealth's Avatar
heres how to make your axles.
http://www.theksource.com/news...re-23
if you have a 5 lug conversion.. i heard you can use k series axles without b-series outer hubs..
Old May 2, 2006 | 05:24 AM
SiKnezzALLmotor's Avatar
Default Re: (EK9-Stealth)
im using same combo but the passenger side im using a prelude shaft with k series inner and b series outter works great over 25 passes on them
Old May 2, 2006 | 09:50 AM
HondaHead211's Avatar
ive seen some amazing thing happen with stock axels. one friend has a built k series on hasport stage 2's and they are great. but ive also seen a boosted ls/vtec puttin out over 350 on stock b16 axels and they have held up for about a year and a half of HEAVY driving. i guess its how confident you are in your axels cause ive personally both extreme ends of the spectrum
Modified by HondaHead211 at 2:20 PM 5/5/2006
Old Jun 27, 2006 | 08:45 AM
2000Accord5sp's Avatar
It's actually been discovered now that you can just use the rsx base axles. I'm using stock rsx base axles with the inner hubs swapped left and right.
Historyg
Nov 9, 2007 01:10 AM
projectwidow
Apr 1, 2007 06:29 PM
john d
Feb 17, 2005 09:41 PM
vtec69
Nov 7, 2002 12:23 PM
