need help on B16A swap into 89crx hf
Old Apr 30, 2006 | 02:17 PM
Sleepingcrx's Avatar
Default need help on B16A swap into 89crx hf
I don't have an engine harness will the stock one work?
but I do have a P30 Ecu and it's hooked up to the crx with jumper harness?
Old Apr 30, 2006 | 02:46 PM
strictlyimport's Avatar
Default Re: need help on B16A swap into 89crx hf (Sleepingcrx)
The stock harness won't work. You will have to find an Si harness or make your own.
Old May 1, 2006 | 08:57 AM
jamclaur's Avatar
I would suggest finding a si harness.
I tried the whole make your own and it was crap... But an SI harness sits perfectly.
Old May 1, 2006 | 10:32 AM
Thanx but the CRX SI or the Civic si with the B16A
and will it hook right up?
Old May 3, 2006 | 12:05 PM
Default Re: need help on B16A swap into 89crx hf (strictlyimport)
Old May 3, 2006 | 12:25 PM
jlicrx's Avatar
use the HF engine harness - everything will plug right in - you will have one connector left over which went to the EGR valve
K20AllMotorEF8
Feb 11, 2012 11:38 AM
jdmsuckah
Sep 2, 2010 01:35 PM
crx89backedout
Jan 14, 2010 03:36 AM
rewerbcrx
11
Apr 14, 2006 01:47 PM
markgo
Feb 29, 2004 06:13 PM
