Suspension & Brakes Theory, alignment, spring rates....
Rear Suspension, Clunk, metal to metal sound, DC4
Old Apr 30, 2006 | 12:55 PM
Yambor's Avatar
Default Rear Suspension, Clunk, metal to metal sound, DC4
Well guys, 320k and counting on the teg and now starting to have suspension problems..
im stumped on this one..
So, i have a flat spot in my tire, left rear (drv side) and some part of the suspension makes this horrible noise, metal to metal, very fast vibrating noise, you can feel it when in the drivers seat, makes it worse when i brake, unloading the rear suspension and it almost stops when i go over 70mph on the interstate..
when going slow, less than 20mph, it just clanks softer, when the flat spot comes around.
It very metallic, pingy, clank , vibrating, almost like the spring is coming unseated and moving around , up and down very fast...
im totally lost , maybe it could be the bushings in the top hat on the strut?
one day the noise totally went away..
it also makes the noise when i turn left, unloading the left side, the noise almost goes away when i have weight in my car, wonder if i can disconnect the sway bar and see if the noise goes away?
any ideas guys?
Old Apr 30, 2006 | 01:47 PM
TunerN00b's Avatar
Default Re: Rear Suspension, Clunk, metal to metal sound, DC4 (Yambor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yambor &raquo;</TD></TR><TR><TD CLASS="quote">Well guys, 320k and counting on the teg and now starting to have suspension problems..
any ideas guys?</TD></TR></TABLE>
With 320k miles, I'm going to bet your bushings are shot. Soulds like all the rubber in at least 1 bushing on the left side is gone, and you're hearing the metal to metal hit. Check your bushings, and replace as needed.
You could disconnect the rear swaybar to see if its the endlinks, but I don't even remember how much rubber there was on the stock endlinks (sphericals for me). And I would guess that the trailing arm bushing would be the first to go, considering the motion of the rear suspension twists that bushing to the side as it rotates.
Old Apr 30, 2006 | 08:01 PM
Yambor's Avatar
possibly, but it looks to me that the trailng arm bushing is fine...
also i cannot get the noise to be made just by pushing up and down on the car while at rest in the driveway..
slateEKsi
15
Aug 10, 2021 04:43 PM
jorge59la
Dec 1, 2010 12:01 AM
danno33
Suspension & Brakes
Aug 24, 2009 05:16 PM
Yambor
May 1, 2006 03:15 PM
xmr. robotox
Suspension & Brakes
Apr 30, 2006 12:44 PM
