Relocate fuse box?
I need to see some pics of relocated under hood fuse boxes, and batteries, in an eg or ej1!!!
Please i have been wanting to do this for quite some time now and i dont want to butcher it and have things go wrong!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egCoupe »</TD></TR><TR><TD CLASS="quote">yeah trust me looked there!! More pictures than how to or detailed info thanks though!!
Run wires through the frame rails, put fusebox under the dash...some put it where the heater box is...thats if you don't want blowing air in your car.
theres alot of info in that linked thread...look again.
Bump for your updates.
</TD></TR></TABLE>Run wires through the frame rails, put fusebox under the dash...some put it where the heater box is...thats if you don't want blowing air in your car.
when i relocated my fusebox, i didnt read any how-to's...
the best advice i received was to unbolt the fusebox, remove all the plugs from the bottom (each plug only fits one spot), and then try to run the wires inside.
your setup is prolly different than mine or the next guys so it all depends on your car... i dont have a/c so i had a hole right behind the battery to run the wires through.
good luck.
good luck.
