Searched Skunk Pro 2 Cams
I have researched and found great things about the pro series skunk cams. I just can't find any good information on the pro series 2s vs the 1s.
I have heard alot about compression with these cams, and my question is go with pro 1s or pro2s?
Current setup:
JDM B18C Block (stock compression)
I/H/E (2.5" collector, full catback apex'i)
60 shot Nitrous
and i have skunk proseries valve springs and retainers, also skunk2 cam gears waiting on a decision of the cams to be installed. Any help is great.
Current setup:
60 shot Nitrous
Both of those cams u mentioned need more compression then a stock GSR, bump your compression up or go with a more mild cam! I run the pro 2's and love them
Good luck with the setup!
[QUOTE=Ls_TurboEG]Both of those cams u mentioned need more compression then a stock GSR, bump your compression up or go with a more mild cam! I run the pro 2's and love them
