Low dyno #'s with B16A2
Old Apr 29, 2006 | 08:28 PM
killerB16A's Avatar
Default b16a? wtf!!!
so i got my car on the dyno today and first pull i did 137whp. i said that ok it needs tuned, so about 2 hours later my last pull was 146whp and 103 torque.WTF!!!! i have type r cams, type r intake manifold, gsr throttle body, aem cam gears, greddy header, 5zeigen exhaust, j's racing intake, type r tranny. can someone explain to me why such low numbers??????? is the gsr throttle body holding me back? i have a chipped ecu and thats what they used to tune it. i got it done at intech racing. HELP
Old Apr 29, 2006 | 09:25 PM
komat's Avatar
Default Re: b16a? wtf!!! (killerB16A)
you sure they are type r cams?
have you done a compression test and leakdown test
Old Apr 29, 2006 | 09:59 PM
professor poon's Avatar
you should probly change your screen-name, considering those dyno numbers...
Old Apr 29, 2006 | 10:01 PM
sol2hatch's Avatar
Default Re: (professor poon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon &raquo;</TD></TR><TR><TD CLASS="quote">you should probly change your screen-name, considering those dyno numbers...</TD></TR></TABLE>
ROFL!!! hahahaa
Old Apr 29, 2006 | 10:04 PM
JDM-EJ1's Avatar
You should probably retake a grade school English class, given that post. Like what was already said I would definitely do a leak down and compression test. Those numbers do seem awfully low for your said setup.
Old Apr 29, 2006 | 10:30 PM
WrongWD's Avatar
i was gonna say decent numbers... but meh ok
Old Apr 29, 2006 | 10:49 PM
broketuner-Sol_Si's Avatar
Default Re: (aallbbeerrtttttt)
Your #s are low for that setup, but things that have a role on #s too are the type of dyno and weather.After you fix whatever may be wrong, you should get nicer #s probably around 160ishHP and 115ishtq.(just basing it on what a friend pulled on a dynojet a couple of weeks ago...he has a similar setup except AEBS IM &TB, and b16 tranny)
Old Apr 29, 2006 | 11:05 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon &raquo;</TD></TR><TR><TD CLASS="quote">you should probly change your screen-name, considering those dyno numbers...</TD></TR></TABLE> HAha.
But yeah, those numbers seem pretty wacky.
Old Apr 29, 2006 | 11:39 PM
killerB16A's Avatar
Default Re:
i will do a compression test and see what i will get. what kind of numbers should i get for compression? i like the name killerb16 it will be turbo here in a few months!!!
Old Apr 30, 2006 | 12:23 AM
maacb16's Avatar
Default Re: Re: (killerB16A)
yeah do the compression and leak down test because those numbers suck really bad
Old Apr 30, 2006 | 01:02 AM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Lol dude don't expect too much from a b16a! my b16 have a valve spring retainer type r cams type r header skunk 2 im stock b16a throttle body made 150whp 109tq I was shock I thought it would be like 160 ish but nope and that's w/o camgears and just some chipped ecu (mugen)
Ur number r kinda good
Old Apr 30, 2006 | 01:22 AM
Timmay's Avatar
Default Re: Re: (spoon95eg)
damn my jdm obd1 b16 swap made 159whp and 115 tq with I/H/E and test pipe then after a few more pulls with more heat would average 155
Old Apr 30, 2006 | 01:35 AM
ZipTieGUy's Avatar
THE GSR TB IS RESTICTING YOU.
Old Apr 30, 2006 | 08:14 AM
spoon95eg's Avatar
B A N N E D
Default Re: (ZipTieGUy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGUy &raquo;</TD></TR><TR><TD CLASS="quote">THE GSR TB IS RESTICTING YOU.</TD></TR></TABLE>
Wrong gsr tb is lil bit bigger than b16a
Old Apr 30, 2006 | 08:22 AM
RockLee`'s Avatar
how lol
Old Apr 30, 2006 | 10:35 AM
killerB16A's Avatar
Default Re:
the guy who tuned it said that the gsr throttle body is holding it back because of the type r intake manifold. he said that the gsr is too small.
Old Apr 30, 2006 | 10:42 AM
spoon95eg's Avatar
B A N N E D
yea of course if u compare it to type r tb and is not that much of a difference if ur using a 2.5 charge pipe but if ur using a 3 inch charge pipe the it is (bottle neck)
Old Apr 30, 2006 | 10:57 AM
killerB16A's Avatar
charge pipe??
Old Apr 30, 2006 | 11:01 AM
MasterKwan's Avatar
What's your compression ratio? If it's below 10.6 or 11:1 I'd expect the R cams just aren't the right cams for you.
Old Apr 30, 2006 | 11:13 AM
spoon95eg's Avatar
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A &raquo;</TD></TR><TR><TD CLASS="quote">charge pipe??</TD></TR></TABLE>
INTERCOOLER PIPE
Old Apr 30, 2006 | 11:20 AM
schardbody's Avatar
if you truly have type R valvetrain and revving past 8500rpm then the numbers are low, however, if you left the rev limiter alone the numbers are on key, the type R valvetrain is designed to shine up top. dont expect much more from bolt ons than 150whp. bump compression, get the motor spinning and numbers will start jumping quicker.
Old Apr 30, 2006 | 12:15 PM
killerB16A's Avatar
Default Re: (schardbody)
ok when i dynoed it i only reved to 8200 or so. when i bought the car the guy told me there where type r cams. im not too sure. how can you tell if they are realy type r? hell i found out that i had a type r intake manifold from the guy who dynoed it. i looked at a b16 intake and a type r intake what do ya know its a type r.
Old Apr 30, 2006 | 12:18 PM
schardbody's Avatar
well, if you dont know for sure i wouldnt rev is too much past 8200. even if they are type R's dont expect to see much higher numbers, maybe 10whp or so.
BauleyCivic's Avatar
Risky Business
Default Re: (killerB16A)
What's the elevation where you are? People at high elevations are going to dyno a lot lower than say, someone near sea level.
Old Apr 30, 2006 | 12:21 PM
schardbody's Avatar
ah, in WA, elevation could play a big part, type of dyno will too.
