cleaning out engine bay
what products should I use to clean off the rust off the engine parts and engine bay?? and what to clean it off with?........i just got a 1994 honda prelude si, silver.........completely stock
you can't really remove rust that easily other than sanding it, but if you wanna get rid of the dirt and grime and grease and ****.... spray some simple green on there for like 5 minutes, scrub a lil bit, then hose off.
shiney new
shiney new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esedulerp5tenin »</TD></TR><TR><TD CLASS="quote"> but if you wanna get rid of the dirt and grime and grease and ****.... spray some simple green on there for like 5 minutes, scrub a lil bit, then hose off. </TD></TR></TABLE>
X2
X2
Gunk Engine Bright and Simple Green. Just make sure u cover all ur electrical stuff, i usually use plastic bags but i also hear tin foil works well because its easily moldable.
CSprogR34
14
Oct 20, 2004 08:37 PM
ekfever
36
Mar 12, 2003 06:17 PM
