OEM LSD?
Old Apr 29, 2006 | 07:21 PM
civic2slo's Avatar
Default OEM LSD?
I was wondering if this is a factory Honda OEM LSD from a 89-91 Civic/90-93 Integra B16A cable tranny? Or is a Spoon LSD unit? Which company makes the LSD for Spoon (OEM Honda)? Last question would this unit fit into a hydro b16 tranny?
Modified by civic2slo at 9:16 PM 4/29/2006
Modified by civic2slo at 11:11 PM 5/14/2006
Old Apr 29, 2006 | 08:06 PM
JeffBro's Avatar
Default Re: OEM LSD? (civic2slo)
more pictures might help. What do you see when you look thru the hole?
Old Apr 29, 2006 | 08:17 PM
civic2slo's Avatar
Default Re: OEM LSD? (JeffBro)
I know its a LSD so I don't think that it matters but heres a pic of the hole.
Old Apr 29, 2006 | 08:58 PM
The Internet Tough Guy's Avatar
my friend had a spoon lsd that looked just like that. apparently ats, cusco, kazz, and maybe a few others look very similar. quaifes look way different, never seen the oem one.
Old Apr 30, 2006 | 03:45 PM
civic2slo's Avatar
Default Re: OEM LSD? (The Internet Tough Guy)
does anyone know for sure what LSD this is? And what it will fit?
Old Apr 30, 2006 | 08:08 PM
civic2slo's Avatar
anyone?
Old Apr 30, 2006 | 08:43 PM
eXcelonTypeR's Avatar
Bense might know lol...someone call the tranny god
Old Apr 30, 2006 | 10:23 PM
JDMFreak's Avatar
Default Re: OEM LSD? (eXcelonTypeR)
i hope this help
OEM CTR LSD
Old May 6, 2006 | 02:17 AM
civic2slo's Avatar
Default Re: OEM LSD? (JDMFreak)
I know how hydro tranny lsd look like. I don't know how cable tranny lsd look like.
Old May 7, 2006 | 07:48 PM
civic2slo's Avatar
anyone have a picture of a cable trannyoem lsd?
Old May 14, 2006 | 10:15 PM
civic2slo's Avatar
Does anyone have pictures of an OEM cable tranny LSD?
Does anyone have pictures of Spoon LSD unit?
Thanks
Old May 17, 2006 | 06:02 AM
Mr.E.G.'s Avatar
i have no idea if this will help but here is the spoon lsd for a type R teg:
http://images.google.com/imgre...a%3DN
although im sure you've seen it
Old May 17, 2006 | 08:05 PM
Crx Jimmy's Avatar
i know its not oem or a spoon, looks like a kaaz, the ring gear monts the other way leading me to that conclusion, its definetly not stock, the stock ones are viscous type and are cone shaped and have 14 bolts on the ring gear, it will fit in a cable tranny as long as its a ys1 with the 4.4 final
Old May 18, 2006 | 11:11 AM
psidriven's Avatar
Default Re: OEM LSD? (Crx Jimmy)
Thought kaaz only makes clutch pack LSD's. This one looks like a gear driven (torsen). Thought honda LSD were torsen not viscous. I'm guessing factory honda, unless someone knows of aftermarket torsen other than quaife.
Old Jun 12, 2006 | 05:54 AM
civic2slo's Avatar
Well you said its not a spoon lsd but here a website that has a spoon lsd. But I can right click and save the picture. I looks identical o mine.
http://www.inlinefour.com/spoonbserlsd.html
Old Jun 24, 2006 | 12:18 PM
K_1's Avatar
K_1
from the looks of the pics you have up top, it looks alot like my tranny, but I wouldn't know how that would help you if it was said that Spoon and a cable tranny LSD look alike.
I just picked up a Y1 tranny with LSD (I think the Stamp was spayed on or something )
<u>Pics of OEM Cable Tranny w/ LSD</u>
driver side
passenger side
if this does not look like LSD, please tell me because if it's not, I'm gonna be pissed! but I'm pretty sure it is though
I hope this helps out a little
edit*
here's a pic of I think a CTR LSD when you look through the hole.
no pics of LSD out of the casing though, but I'm pretty sure it looks like the pics that JDMFreak has posted above
Old Jun 24, 2006 | 05:08 PM
jdmeg9's Avatar
Default Re: OEM LSD? (K_1)
as long as you can see through the hole it is a lsd, if it has a bar in the hole then it is closed diff
Old Jun 26, 2006 | 02:00 AM
DARKB20's Avatar
Default Re: OEM LSD? (jdmeg9)
more info
Old Jun 26, 2006 | 05:14 AM
black_EM1's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">as long as you can see through the hole it is a lsd, if it has a bar in the hole then it is open diff </TD></TR></TABLE>
Fixed
Edit: I don't know jack about cable trannies.
Rishiras
Oct 20, 2009 02:28 PM
HT Chaplain
Mar 30, 2005 06:39 PM
monicle
Nov 26, 2003 07:21 AM
