Suspension & Brakes Theory, alignment, spring rates....
crx ingalls camber kit 35720 install? help work in progress!!!!!
Old Apr 29, 2006 | 05:46 PM
blackwagon's Avatar
Default crx ingalls camber kit 35720 install? help work in progress!!!!!
The metal tube in the bushings definlty doesn't fit in, am I doing somthing wrong?
I searched and no one mentioned anything about grinding of the metal peice for it to fit. The bushings themselves, without the metal peice, fits so I guess i'm making this post to make sure i'm not retarded, maybe theres some way for a square peg to fit into a round hole.
Should I grind it down and call it a day or is there some other way of doing this im not seeing...
#1 is where #2 would go into, #2 is about 1/8" to big for it to work. There is no way to bend open #1 for it to fit because it would just make a wedge and not a parallel opening for #2 to fit in.
Old Apr 30, 2006 | 07:28 AM
MasterKwan's Avatar
Default Re: crx ingalls camber kit 35720 install? help work in progress!!!!! (blackwagon)
Where'd you get that upper control arm?
serjey15
Jan 26, 2011 10:08 AM
blackwagon
May 1, 2006 07:43 PM
blaak-crx
Sep 7, 2005 12:51 PM
Gunmetal_B20_Hatch
Jun 5, 2005 11:43 PM
insomniac791
Sep 5, 2003 10:53 AM
