timing belt package question(searched)
Old Apr 29, 2006 | 03:41 PM
94hatchvx's Avatar
Default timing belt package question(searched)
ok. i have a 1992 honda civic cx with a b16 sir2. right now it is all stock. i was driving it yester day and it made a weird noise so i shut it off and coasted into a parking lot.I popped my hood and noticed that my timing belt was near snapping, so of course i towed it to my house to prevent snapping it and bending valves. I found out my tensioner failed and the belt rubbed on something.I decided it was smart just to order a OEM timing belt package and replace it all. So i bought one with oem belt,tensioner,and water pump. I finaly got it and now i need to put it in. I was wondering how to do this. i have no money to pay a mechanic to do it but I have a fair nowlege of my motor. I was wondering how to do this step by step and if it is posible to do it with the head on and the motor in the car. any help would be apreciated. i have a jack and stands but now engine hoist. plz help. this is my daily driver and i need it runnin again asap. plz help honda-tech.
Old Apr 29, 2006 | 04:15 PM
GS-R Civic's Avatar
Default Re: timing belt package question(searched) (94hatchvx)
dam i just did a whole write up and lost it when i went to upload some pics.
what exact problems are you having? get a $15 haynes manual and it will walk you through it.
get one of these
This will allow you to remove the bolt from the crankshaft pulley. This is the most difficult thing i have ever faced. Tool costs about $70 the number on it is 60100.
I really don't want to type it all up again so ask any specific questions.
Old Apr 29, 2006 | 04:20 PM
GS-R Civic's Avatar
pm me with questions if u want
Old Apr 29, 2006 | 04:26 PM
94hatchvx's Avatar
Default Re: timing belt package question(searched) (GS-R Civic)
i need to instally the new tensioner,waterpump and timing belt. but i have no way to pull the motor. is this possible to do with it in?
Old Apr 29, 2006 | 04:45 PM
SVOboy's Avatar
Get a manual for whatev car the engine came from and follow it step by step to change the stuff on your engine, good luck.
Old Jun 21, 2006 | 11:19 AM
RiceKillinSI's Avatar
You can get the crank pulley tool at http://www.amazon.com/gp/produ...28013 for $25.
Old Jun 21, 2006 | 11:39 AM
Archidictus's Avatar
Unceasing Measure
Default Re: timing belt package question(searched) (RiceKillinSI)
Old Jun 21, 2006 | 01:44 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: timing belt package question(searched) (Archidictus)
Here is a great writup about changing your timing belt & water pump on a SOHC. A DOHC is mostly the same (secept for the second cam gear ). You would have found this in the "links" thread at the top of this forum if you searched hard enough:
https://honda-tech.com/zerothread?id=649277
Too bad that Del Sol was stolen last year...
Old Jun 21, 2006 | 02:10 PM
94hatchling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">i need to instally the new tensioner,waterpump and timing belt. but i have no way to pull the motor. is this possible to do with it in?</TD></TR></TABLE>
you dont have to pull the motor just to change the timing belt, water pump, and tensioner. you will however need to support the motor from underneath with a jack and a 2x4 on top becuase you have to remove the driver side motor mount. i just did mine about a month ago. its really not difficult. just make sure you get everything lined up and the timing dead on when you are installing the timing belt.
and if you can get one of these, it will make the job MUCH easier. it locks the cam gears in place before you take off the old belt, that way you dont have to worry about them moving while installing the new belt.
Old Jun 22, 2006 | 08:12 AM
mingbling96's Avatar
Default Re: timing belt package question(searched) (94hatchling)
that tool are for amateurs
Old Jun 22, 2006 | 08:14 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: timing belt package question(searched) (mingbling96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">that tool are for amateurs</TD></TR></TABLE>
Your typing are for amateurs... j/k
Old Jun 22, 2006 | 08:20 AM
oh yeah? i didnt say it was needed, just said it made the job easier.
and to correct you, the proper way of saying that would be "that tool is for amateurs".
Old Jun 22, 2006 | 09:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling &raquo;</TD></TR><TR><TD CLASS="quote">
and to correct you, the proper way of saying that would be "that tool is for amateurs". </TD></TR></TABLE>
Vasaline makes most jobs easier too.. Do you use that?
Old Jun 22, 2006 | 09:10 PM
Crazydave's Avatar
also search for how to take the crank pulley bolt off..
that will be the biggest bitch of the job.
I use an air gun to loosen that bolt.
also while you are at it, check the condition of your other belts (alternator, a/c, power steering) this would be a good time to replace these too.
Old Jun 22, 2006 | 10:50 PM
.Kevin.'s Avatar
Default Re: timing belt package question(searched) (Crazydave)
I dont wanna be an *** but i assure you that if you do not know what you are doing do not do this. If the timing is off it will hurt the motor. On a side note though I had much confidence and was able to do this. I also had air tools and I highly reccomend having them because they make the job a lot easier. That DIY pretty much sums up everything needed to know.
ALLxMotor DA
Sep 6, 2008 06:10 AM
1baddcivicsi
Oct 13, 2006 06:19 PM
94hatchvx
Apr 30, 2006 06:29 PM
Steak84SS
May 26, 2004 04:18 PM
jerm001
10
Dec 24, 2003 02:03 PM
