Timing issue! Help!
Ok I have a JDM B16 and it runs like ****!!! Vtec hits so weak and it bogs everytime I shift. So I set my engine to TDC today and took some Pics. Im unsure of the way timing on a b16 should look. But I was told by a good friend of mine that it's off by a tooth and the up signs arent facing the way they should, he said on a b16 they should be facing forward a little bit...PLEASE HELP!!
the timing may be fine. What u need to do is check the marks also by the gear and the crank pulley and make sure they meet at the mark on the oil pump. they might meet if you spin the crank a tad CCW and the lines at the bottom may meet up. Also check the dizzy timing.
you are off 1 tooth on the exhaust side (IF the crank is at TDC, if its 100% at TDC move the exhaust cam 1 tooth counter clockwise, spin the motor over a few turns and back to TDC, make sure it all lines up.
Well it wasnt DEAD on TDC. Of the 4 marks on the Crank Pulley the first 3 it was on the last one. It had to be on the last one for the UP signs on the cam gears to be both upright. So I guess my timing is then retarded then? Ill line it up DEAD on TDC tomorrow and take more pics but until then whats your opinion on what I just said? and tell me if you need to explain it a lil bit better! :D
SCREW IT ILL PHOTO SHOP AN EXAMPLE
There we go. Those of you who know your **** will know what TDC looks like blah blah. Imagine that Crank Pulley on a B16. and if your lookin at it from over your engine bay...whatever fender where ever it is you look at it from. when I had the UP arrows pointing straight up it was sitting on that 3rd mark the arrow in the picture is pointing to.
Dumbass me. Dont go by that pic I will update pics tomorrow I didnt have the **** set at TDC. I cant believe I didnt realize that Ill show updated pics later today.
no the UP on the gears should be straight up and the notches on the gears should line up, all when the #1 cylinder is at TDC. the 3rd line on the pulley isnt TDC, its the next one all by itself, just incase you didnt know.
No I knew that I just didnt pay attenion when I was doing it yesterday. But I did it right today. I even cleaned my Vtec Solenoid and still. My car bogs when I shift and Vtec hits but not as hard as a B16 usually would.
Someone please help me!!
My car is full of problems. Now some oil is slowly seeping out of the front of my engine where the VC meets the head...So now I need a new VC gasket right? help not to sure.
