How do you remove the Ebrake handle?
Old Apr 29, 2006 | 01:58 PM
Andrew Marquis's Avatar
Default How do you remove the Ebrake handle?
Well, my Ebrake handle has seen better days-- PIC...
I was just trying to figure out how to get it off.. so I can replace it.
Thanks, and yeah it's probably going to be pretty simple... i'm just a tard...
-Andrew
Old Apr 29, 2006 | 02:27 PM
CoolRedXylophone's Avatar
Default Re: How do you remove the Ebrake handle? (bakerboy4679)
just remove the plastic trim around the base and then the handle should slide off with some pulling
Old Apr 29, 2006 | 02:33 PM
ol'rex's Avatar
Default Re: How do you remove the Ebrake handle? (CoolRedXylophone)
you would be better off taking the whole e brake offand geting an other one from a wrecking/salvage yard for ten bucks there are only like four or five skrews and two bolts and unhook the cables
Old Apr 29, 2006 | 02:58 PM
.Manny.'s Avatar
Touching My Member
just pry at that top piece, it will pop off
Old Apr 29, 2006 | 05:51 PM
aight thanks fellas
Liquidgsr
Apr 26, 2006 10:20 PM
giff74
Mar 19, 2005 02:09 AM
subgeniusdude
29
Feb 18, 2004 10:09 PM
