'93 Integra Motor (B18A1/YS1) into 1991 Integra LS/GS
Old Apr 29, 2006 | 01:32 PM
g2tegsownsgirl's Avatar
Default '93 Integra Motor (B18A1/YS1) into 1991 Integra LS/GS
Hello,
I have a 1993 Integra RS w/ B18A1/YS1 can I put that motor into a 1991 Integra LS or GS without any modification of any kind? If not what kind of modification(s) would be required?
Thanks,
Old Apr 29, 2006 | 01:33 PM
projectTeG's Avatar
you have to use the obd0 componets and the driverside engine mount
Old Apr 29, 2006 | 04:39 PM
And the '93 Integra RS has a B18A1 right? Which is OBD-1 right? If so don't I only need an Alternator and a Distributor from the plain old B18A (OBD-0)?
Modified by g2tegsownsgirl at 6:36 PM 4/29/2006
Old Apr 30, 2006 | 07:52 AM
Please someone help me, I need to know so I can buy the car before someone else does.
Old Apr 30, 2006 | 10:12 AM
Black Widow g2's Avatar
Default Re: (g2tegsownsgirl)
no. you're going backward in obd factor. you will have to splice and solder some of the wires because not all of the plugs will go directly in.
also, the ecu it is using has different connections, so you will need a jumper harness.
although it is the same motor, and it will directly bolt in, it will need some work. i'm wondering why you don't just drive your 93? why put it in an older car?
Old May 1, 2006 | 03:49 AM
Default Re: (Black Widow g2)
Well mine has rusted to death, and there was a good deal on a 91 in my area, if I buy a 92-93 they both have B18A1 engines that are OBD1 right? And there should be no modification(s) at all right? Oh BTW I don't know if this matters but I would be going from my '93 RS into a LS, I know the LS had all the goodies, don't know if that will complicate things or not.
Thanks guys,
Old May 1, 2006 | 08:36 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2tegsownsgirl &raquo;</TD></TR><TR><TD CLASS="quote">Well mine has rusted to death, and there was a good deal on a 91 in my area, if I buy a 92-93 they both have B18A1 engines that are OBD1 right? And there should be no modification(s) at all right? Oh BTW I don't know if this matters but I would be going from my '93 RS into a LS, I know the LS had all the goodies, don't know if that will complicate things or not.
Thanks guys,</TD></TR></TABLE>
yes this is the same reason i swaped from my 93 ls to a 91 rs, i converted the 91 to obd1 using everywwireing harness in the car and also converte4d it to power windows.
to get that engine in your car you need the to used the obd0 90-91 harness and the odb0 distributor , injectors, and ecu.also you need to have the 90-91 teg driver side engine mount
does the 91 Ls come with a engine? if so why not just take the Intake manifold and cams out of the 93 rs and you basically have a 92-93 B18a
Dannyboi91
Sep 1, 2016 09:42 AM
&dRooLz
Mar 3, 2009 07:38 PM
MYDA9
Dec 20, 2004 02:20 PM
