changing rear brakes...need quick help
You twist it just like a screw, and it will compress,
Just use a Big screwdriver and stick it in there sideways.
It should be pretty straight foward on how them come off too,
Maybe like two bolts towards the inside holding it on.
ok ok i got it...i have to changemy rotors too...there is 2 screws that i have to take out...but how do i get the rotor to stay still when i am tryin to unscrew?
Loosen the rotors before you take the calipers off?
Or try sticking a rod between the studs to hold it in place, I'd put the lugnuts on to crank on it so you don't damage the threads as you hold it.
To remove the two screw, use an impact driver and hammer.
Here is how an impact driver looks like:
http://www.sears.com/sr/javasr...41000
You can also get the impact driver from other places that sell automotive tools.
Kyle905
Apr 3, 2011 02:18 PM
