Are the fuel pump assemblys different between a 92-95 civic and 94 delsol?
Old Apr 29, 2006 | 08:26 AM
calinomad's Avatar
Default Are the fuel pump assemblys different between a 92-95 civic and 94 delsol?
my delsol got stolen i had no choice to put a civic fuel pump in and i noticed at about 1/4 tank the car would run out of gas it almost seemed as if the fuel pump was different and wouldnt register all the fuel in the tank.The amount of gas was accurate but i could never run to the end only till about 1/4 tank or above. my previous fuel pump assembly never did that before stolen. Can u guys help me i bought a 95 delsol fuel pump assembly just waiting for it . My mechanic metioned that the fuel assembly from the civic was a bit tough to put in as if the lines ran different. i dont know.
Old Apr 29, 2006 | 09:04 AM
egredspools's Avatar
Default Re: Are the fuel pump assemblys different between a 92-95 civic and 94 delsol? (calinomad)
It also depends if the del sol has b16,d16 or the non-vtec motor and the civic?
Old May 1, 2006 | 06:09 PM
calinomad's Avatar
Default Re: Are the fuel pump assemblys different between a 92-95 civic and 94 delsol? (egredspools)
well i changed the fuel pump already and it appears the fuel pump on a delsol is straight down and the civic fuel pump which was was installed had a high heal shape not straight so when putting both aside u can notice a 25% difference in length which was a 1/4 tank so thank you.
flanker
Oct 2, 2016 11:07 PM
djakob
Nov 6, 2012 01:31 PM
EKSedAndy
Nov 12, 2007 10:22 AM
90AcuraIntegra04
Jan 4, 2006 11:00 PM
