93 dx auto to manual with a b serie swap
Old Apr 29, 2006 | 08:16 AM
EK FLY's Avatar
Default 93 dx auto to manual with a b serie swap
my friend found a great deal on this 92 well trake care dx auto hatch he is going straight for a gsr swap I have read that the chassis of a manual is diferent than the auto one if so I was wondering what mount should I use I allready have a list of what I need for the auto to manual swap but thats for the d serie motor
Old Apr 29, 2006 | 09:46 AM
vestalfootball72
Guest
Posts: n/a
Default Re: 93 dx auto to manual with a b serie swap (TURBO-WAWA)
You can either cut off the tranny mount and weld it on lower or you can get the hasport conversion- i recomend the hasport even tho when i did my swap i welded it- itl look cleaner. The shift linkage doesnt really match up when your installing the shifter other then that its not too bad
Old Apr 29, 2006 | 10:03 AM
EK FLY's Avatar
Default Re: 93 dx auto to manual with a b serie swap (vestalfootball72)
do u have the hasport part # for that mount ?
Old Apr 29, 2006 | 10:56 AM
tatmark1's Avatar
i got a innovative mount from passwordjdm for a bill works great
Old Apr 29, 2006 | 02:51 PM
EK FLY's Avatar
Default Re: (tatmark1)
if I descide to cut the braket how low should I bring it down or move it back or fwrd
Old Apr 30, 2006 | 02:13 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">The shift linkage doesnt really match up when your installing the shifter other then that its not too bad </TD></TR></TABLE>How is that? The last "auto-to-manual" I did came out perfect.
Old Apr 30, 2006 | 02:43 PM
vestalfootball72
Guest
Posts: n/a
Default Re: 93 dx auto to manual with a b serie swap (NVturbo)
i shoudl have stated it better- the holes in the floorboard do not line up right so you do have to drill around a little- my bad sorry for that
anzi
Transmission & Drivetrain
Feb 8, 2011 06:55 PM
thegooddoctorceretti
Jun 11, 2007 06:22 PM
getnasty
Nov 17, 2005 12:56 PM
cchhrriiiss
Oct 7, 2005 06:48 PM
JswineyHB93
Aug 12, 2004 03:39 PM
