All motor lude at the track
Old Apr 29, 2006 | 06:30 AM
junbb1's Avatar
Default All motor lude at the track
Well I decided i would go to the track at about 7:00 pm Late decision but I had an itch. I put on my 7 year old 205 50 15 BFG radials. These are the ones BFG had before they even started making the ones for imports.
Typically when I go to the track i will get there with about 1.5 gallons of gas but last night was such a last minute decision i showed up with approx 6 gallons. about 40lbs heavier then I would like.
The conditions were excellent I must say about 60-65 low humidity and no wind.
The only down fall was that the track was ungodly packed. I got in the lanes at 8:30 and was only able to make 2 runs which the second started at 11:20. But any ways...
first run: 60: 2.11
1/8: 8.643
mph: 83.346
Pretty good traction in the right lane but i have hit 2.0 60' in the past. but this was my first pass. I have always been able to cut 2.1 60' very consistantly.
Now having said that the second run in the left lane was a terrible 60'. I have not pulled one that bad in years.
second run: 60: 2.416
1/8: 8.867
mph: 85.225
Now considering the shitty 60' there is some promise with the second run. Easily with a 2.1 60' the times would be low 8.50's and with my fuel weight down 8.4 is very possible with a 2.1 60 ft. Plus the trap speed is pretty impressive.
And for you lazy asses, read the whole post.
Here is the set up and dyno
https://honda-tech.com/zerothread?id=1555815
Suspension is tanabe coilovers.
ESMM
aaronISthrowed
Feb 15, 2007 06:46 PM
junbb1
May 3, 2006 09:35 PM
junbb1
Apr 30, 2006 06:02 PM
b19coupe
Feb 8, 2003 12:44 PM
1 2 NV
Jul 4, 2002 11:04 PM
