remove pin from harness under the hood
Hey, I'm trying to remove some pins from the harness under the hood, but I'm having a hard time figuring out how to remove them. I've searched and only came up with how to remove pins from the connector to the ecu only.. I've already removed those, but now i need to remove the one's under the hood.
Generally, to remove pins from electrical connectors, harness, etc., a pin extraction tool is used to to push the pin out. There a different size extraction tools available to match the size of the pins being extracted.
if you are refering to the harness connectors for the engine you have to first remove the white plastic insert . Once that is removed you need a small pick or a pin or even a really small flathead screwdriver to insert into the connector and release the pinfit while pulling out on the wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 »</TD></TR><TR><TD CLASS="quote">if you are refering to the harness connectors for the engine you have to first remove the white plastic insert . Once that is removed you need a small pick or a pin or even a really small flathead screwdriver to insert into the connector and release the pinfit while pulling out on the wire.</TD></TR></TABLE>
thanks, i'll try and look for that white plastic piece.
Alex Flores
Sep 5, 2015 01:00 AM
skunk2unerz
34
Mar 15, 2012 11:27 AM
shadykit
Jun 14, 2004 07:16 AM
typer 00-115
Audio / Security / Video
Feb 28, 2003 05:38 PM
