Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Mugen Bushings
Old Apr 28, 2006 | 09:09 PM
Draco's Avatar
Default Mugen Bushings
I am currently in the process of replacing all my front bushings in my 94 Civic Si. I replaced all the rear bushings with OEM, and I'm debating on using the Mugen bushings for the front. I've been searching around for awhile now on which Mugen bushings correspond to the OEM part numbers. I know what Honda part numbers the bushings I need are thanks to the search database on hondaautomotiveparts.com. Following is a list of the OEM part number and what I think the corresponding part number on King Motorsports website is.
Front LCA Bushing (2)
OEM - 51392-SR3-024
Mugen - 51392-XG5-S0N0
Damper Fork Bushing (2)
OEM - 51810-SH3-004
Mugen - 51810-XE5-S0N0
Front Compliance Bushing (L)
OEM - 51396-SR0-A02
Mugen - 51391-XG5-S0N0
Front Compliance Bushing (R)
OEM - 51395-SR0-A02
Mugen - 51391-XH3-S0N0
Front Swaybar Bushings (8)
OEM - 51312-SR3-000
Mugen - 52316-XE5-S0N0
Front UCA Bushings (4)
OEM - 51455-SR3-003
Mugen - 51455-XG5-S0N0
The part number that's really confusing me is the compliance bushing. King Motorsports lists one part number yet OEM specifies two separate part numbers. I am also confused as to the quantity of bushings sold in each "set" as labeled on King Motorsport's site. The prices seem to correlate with each set having the required number of bushings, but I'd really like some confirmation. Seeing as many of you have ordered Mugen bushings from King before, I would assume the answers can be readily found here.
Any input would be greatly appreciated. Thanks.
Old Apr 29, 2006 | 12:07 AM
chrisw85's Avatar
for the front lower arm and upper, i think these would be better and cheaper overall:
http://www.orijinmotorsports.com/prodegen.html
but, do check the upper ball joint. would make no sense to replace the inner bushnigs and have bad ball joint. you can pick up a new pair of upper arms on ebay for ~$65 plus shipping, then just put the spherical into that.
compliance bushing is that radius-rod like thing. i dunno if there is a spherical for that.
as far as the sway bar bushings are concerned, go with energy poly for the D-bracket bushings and the endlinks. the D bushigns are like $7 and the endlink kit is like $13.
Old Apr 29, 2006 | 07:22 PM
Draco's Avatar
Default Re: (chrisw85)
Since I autocross in STS, spherical bearings are a no.
"If the Stock bushing accommodated multi-axis motion via compliance of the component material(s), the replacement bushing may not be changed to accommodate such motion via a change in bushing type, for example to a spherical bearing or similar component involving internal moving parts."
If someone can guarantee me that the Orijin products you suggested would be legal in STS, then I would consider that option.
I'm also replacing the upper arms with Skunk2 adjustable arms, so the ball joint will be replaced then.
Can anyone help me out on the Mugen bushings question?
Old Apr 29, 2006 | 08:39 PM
RStoR's Avatar
Default Re: (Draco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Draco &raquo;</TD></TR><TR><TD CLASS="quote">
Can anyone help me out on the Mugen bushings question?</TD></TR></TABLE>
IM Ausmith. He works at King and should be able to answer any questions you have.
Old Apr 30, 2006 | 09:17 PM
NinetyTwoHB's Avatar
Energy Suspension works great and wont cost as much as Mugen.....
Old May 1, 2006 | 08:47 AM
ekim952522000's Avatar
Default Re: (NinetyTwoHB)
Just call king that's what I did and told them what I was looking for and they sent me the ones I wanted, sometimes it's easier just to call.
Old May 1, 2006 | 10:46 AM
MasterKwan's Avatar
Default Re: (ekim952522000)
These guys are still selling their kits but, are getting out of the suspension business
I emailed them about sperical bearings for an EK and that was the answer I got. He also said the EK upper control arm didn't have the same camber problems the Integra/EG ones did.
Old May 6, 2006 | 04:05 AM
Ausmith's Avatar
Default Re: Mugen Bushings (Draco)
All Mugen bushings are sold in sets to cover both sides of the car. You were pretty close:
OEM - 51392-SR3-024
OEM - 51810-SH3-004
Front Compliance Bushing (2)
OEM - 51396-SR0-A02
OEM - 51312-SR3-000
OEM - 51455-SR3-003
I would suggest using poly bushings on the sway bar, they will last longer. The front lower arm, front compliance, and front UCA bushings are key.
Old May 8, 2006 | 03:09 PM
rmcdaniels's Avatar
Default Re: (Draco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Draco &raquo;</TD></TR><TR><TD CLASS="quote">"If the Stock bushing accommodated multi-axis motion via compliance of the component material(s), the replacement bushing may not be changed to accommodate such motion via a change in bushing type, for example to a spherical bearing or similar component involving internal moving parts."
Wouldn't that only apply to the rear trailing arm bushings? I thought that the front LCA bushings that Orijin makes a kit for are only supposed to move on one axis.
Old May 30, 2011 | 01:53 PM
Jimmy's Avatar
Global Moderator
Part numbers for OEM ITR Compliance bushings:
51396-ST7-Z01
51395-ST7-Z01
Is the bracket included with these?
Old May 30, 2011 | 05:30 PM
dirty19's Avatar
Ridin Dirty in Cali
51396-ST7-Z01
51395-ST7-Z01
Jimmy has been in a coma for a spell now so please excuse the late answer.
I dont think anyone uses Mugen bushings anymore.
Hardrace Baby!
Old May 30, 2011 | 06:35 PM
chrisb's Avatar
A lot of people use Mugen stuff or just factory Honda stuff. Hopefully even "hardrace" can't mess up plain old metal/rubber bushings. But I wouldn't put it past them. Personally, I don't put parts from Taiwan, China, subsaharan Africa, random 3rd world countries etc. on my race car. But that is just me. I understand it is the cool thing to do in Cali. ;-)
Old May 30, 2011 | 07:17 PM
RR98ITR's Avatar
Bushings...control arms...space...full of other things going on...and in the way...and forces...bing input where you don't want them...and it's not like you have much choice...I'm tired of this particular headache...
Scott, who..."Chris, you've got email"...
Old May 30, 2011 | 08:03 PM
dirty19's Avatar
Ridin Dirty in Cali
Where do you think those Mugen bushings are made ol wise one.
Your beloved third world countries you speak of.
Do your research and know where your car is really from.
You'll find china comes up in almost every component.
Hardrace on my race car, because it has never failed me.
Its my prefered brand.
Old May 30, 2011 | 08:22 PM
Jimmy's Avatar
Global Moderator
Hardrace Baby!
I was just doing some searching.. I searched hard race and seeing positive review and I also seen where people put it was a cheap low quality bracket that rusted, etc.
That's all that is on my car if it's brand new. OEM Honda.
''Made in Japan'' to me usually indicates quality product
DC2*Integra
Suspension & Brakes
Aug 21, 2008 02:40 PM
wickedEFguy
23
Dec 31, 2007 12:46 PM
Jeff_B
40
Dec 20, 2005 08:29 AM
p1driftfiend
24
Jul 10, 2004 12:25 AM
pbcdb
Dec 23, 2003 04:44 AM
