CTR rear sway bar?
Old Apr 28, 2006 | 07:36 PM
r1de4life's Avatar
Default CTR rear sway bar?
will any lower control arms work with CTR rear sway bar work on a 92-95 hatch???
Old Apr 28, 2006 | 08:01 PM
pdiggitydogg's Avatar
huh? I cant figure out what youre asking...
But...If your current lca's have holes for endlinks, yes. If not, get ones from a 94+ integra.
You do know that you will have to reinforce the subframe to run a bar that size, right? Otherwise, you will tear it...
Old Apr 28, 2006 | 08:52 PM
Spoon-EK9's Avatar
Default Re: CTR rear sway bar? (r1de4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1de4life &raquo;</TD></TR><TR><TD CLASS="quote">will any lower control arms work with CTR rear sway bar work on a 92-95 hatch???</TD></TR></TABLE>
it's better to put ITR LCA with ITR sway bar. CTR and ITR are both 22mm in size. no difference
Old Apr 28, 2006 | 10:09 PM
papito_85's Avatar
Default Re: CTR rear sway bar? (Spoon-EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon-EK9 &raquo;</TD></TR><TR><TD CLASS="quote">
it's better to put ITR LCA with ITR sway bar. CTR and ITR are both 22mm in size. no difference </TD></TR></TABLE>
then why is it better to put an itr bar instead of an ctr if they are both the same?
Old Apr 29, 2006 | 12:56 AM
johnecon2001's Avatar
Default Re: CTR rear sway bar? (papito_85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papito_85 &raquo;</TD></TR><TR><TD CLASS="quote">
then why is it better to put an itr bar instead of an ctr if they are both the same? </TD></TR></TABLE>
Read what he said genius. He didn't say the ITR bar was better than the CTR one.
He said to use ITR LCA's instead of aftermarket ones. Especially since the CTR and ITR sway bar are the same.
Old Apr 29, 2006 | 02:14 AM
BlueIntegraBoy's Avatar
I'm running an ITR rear sway with Omni LCAs. You don't necessarily need ITR LCAs unless you want to spend more on rear struts.
Old Apr 29, 2006 | 03:27 AM
why swap on itr lcas at all? then you have to change your shocks...
Just get plain old usdm integra lcas and be done with it
Kennyjai
Jun 22, 2012 09:36 AM
mister H
May 20, 2007 03:57 PM
saveacivic
Suspension & Brakes
Apr 15, 2006 12:31 AM
Mr. Choi
Jan 17, 2004 04:06 PM
hazard_one
Jan 7, 2004 10:43 AM
