96 wheel offset
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lamsv »</TD></TR><TR><TD CLASS="quote">42mm offset should be fine. Offset won't mess with your speedo one bit. Overall tire diamter will though.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">Hm.. how much will it mess with my speedo, isn't there a way to make it so that it doesnt?</TD></TR></TABLE>
Use this tire calculator. Put what your factory size on the first side, and what you want to run on the other side. This will give you all the specs you need...
http://www.discounttire.com/dtcs/infoTireMath.dos
Good luck
Good luck
.ShawnD.
Aug 14, 2003 11:14 AM
