dpfi to mpfi swap i got code 9
Old Apr 28, 2006 | 11:31 AM
cjwarren4dcivic's Avatar
Default dpfi to mpfi swap i got code 9
how do i check it or are those wires supposed to be loomed with sheilded wire
Old Apr 28, 2006 | 01:03 PM
court's Avatar
25 Year Member
Default Re: dpfi to mpfi swap i got code 9 (cjwarren4dcivic)
a little more info
Old Apr 28, 2006 | 01:40 PM
si90rex's Avatar
CODE 9 is the #1 postion senor right. will if it is u need a new distributor mostly. the senor is built in to the casting. mine came on and after about a week the coil burned up and the then a had to replace the coil, cap and distributor casting. if i'm right u might want to replace it soon or u could be broke down some were because you have no fire.
Old Apr 28, 2006 | 02:51 PM
bossman032's Avatar
Default Re: dpfi to mpfi swap i got code 9 (si90rex)
that is the ckp code.
that will rev limit u to 3500 rpms.
most likely a wiring mess up.
check your wiring....
Old Apr 29, 2006 | 09:35 AM
no wat i meant is does it have to be in a sheilded wire
Old Apr 29, 2006 | 11:12 AM
Dohc 4door Rye's Avatar
i had the same problem with my DPFI to MPFI i ended just running everything straight to ecu because i was not sure what wire was wrong make sure all your wires are all going into the right spot the 2 white wires are easy to confuse
i used the chart off http://www.fourthgenhatch.net/mpfi.html it helped me big time
alot of other websites i found out to be wrong which is how i ran into the problem in the first place
and make sure everything is sodered and no wires are touching others
Old Apr 29, 2006 | 03:12 PM
and it cant be the dizzy or ecu because came off a car with no codes noone will answer my real ??
Old Apr 29, 2006 | 03:26 PM
bossman032's Avatar
check ur wiring fool.
learn how to read also.
its obvious.
this is a common problem ckp and tdc codes..
Old Apr 29, 2006 | 06:36 PM
court's Avatar
25 Year Member
what ecu are you running
what dizzy are you running
Old Apr 29, 2006 | 07:31 PM
90 civic ex manual ecu and dizzy
Old Apr 29, 2006 | 10:38 PM
court's Avatar
25 Year Member
if you are running a pre obd diz and computer and it was a known working dizz, then
A: bad ecu
B: faulty wiring.
I just re-did my dpfi to mpfi wiring and the correct solder and quality high impediance wire made a large difference.
your cylinder position code is possibly due to the 2 white wires switched
Old Apr 29, 2006 | 10:48 PM
janz3n's Avatar
Default Re: dpfi to mpfi swap i got code 9 (court)
if those two white wires are switched the car wont even start though, iv got the same problem and dont know whats going on. iv tried everything and i havent gotten rid of this code. im sure my wiring is right, and please dont say check it again cuz iv checked it about 5 times and redid it about 2 times. iv even replaced my dizzy once and still get the code but the car will run alot better but i get hesitation at 3000rpms sometimes. not all the time.
Old Apr 29, 2006 | 11:25 PM
soslodelsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjwarren4dcivic &raquo;</TD></TR><TR><TD CLASS="quote">and it cant be the dizzy or ecu because came off a car with no codes noone will answer my real ??</TD></TR></TABLE>
yes shield it. it has to be protected from RFI
and solder your wiring instead of just electrical tape.
Modified by soslodelsol at 1:10 AM 4/30/2006
Old Apr 30, 2006 | 07:22 AM
janz3n's Avatar
Default Re: dpfi to mpfi swap i got code 9 (soslodelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soslodelsol &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by soslodelsol at 1:10 AM 4/30/2006</TD></TR></TABLE>
so do you think im getting code 9 because i used speaker wire.. not car speaker wire just some black wire from the source(radio shack)
Old May 1, 2006 | 11:25 AM
Default Re: dpfi to mpfi swap i got code 9 (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">
so do you think im getting code 9 because i used speaker wire.. not car speaker wire just some black wire from the source(radio shack) </TD></TR></TABLE>
my friend ran into that problem too. have a look at your wiring and make sure all the connections are good and protected. a little makes a big difference.
the quality shouldnt matter as much. check resistance for the crank sensor/ whatever and check to see if its within specs
DA9Sleeper
Nov 6, 2011 06:57 AM
ZCeddie586
Jun 23, 2011 09:01 PM
jcyaj
15
May 30, 2007 05:14 PM
Sobe_Death
Mar 11, 2004 10:09 AM
JonGP4
Jul 26, 2003 06:13 AM
