i spun a rod bearing and need some help..
Old Apr 28, 2006 | 07:18 AM
eklum's Avatar
Default i spun a rod bearing and need some help..
i spun a rod bearing on my d16y7 yesterday and im going to have to replace them my self i was wondering if any one had the trq. specifications i need for .. oilpan.. fuelpump..<U> everything</U> all the way to the rod.
please help me out and if you got any useful info lemme kno thanks!
Old Apr 28, 2006 | 07:39 AM
t0p_sh0tta's Avatar
Default Re: i spun a rod bearing and need some help.. (klum)
lol, your fuel pump has nothing at all to do with your rod bearings. Buy a HELMS factory service manual, and say a prayer before you start tearing **** up.
Old Apr 28, 2006 | 08:01 AM
cibola's Avatar
Get a Helms and even then the bearing spacing is real tricky
Old Apr 28, 2006 | 08:23 AM
tractiondeprived's Avatar
Default Re: i spun a rod bearing and need some help.. (t0p_sh0tta)
fuelpump? man u sure you really wanna replace it yourself? its not exactly something you would want to tackle if you dont really know what you're doing. while you're in there i would go ahead and replace the main bearings and i'm sure you're aware that you also should replace thrust washers if you're in there anyway. are you planning on reringing it or just taking the rod off the crank and putting the new bearings in with the piston still in the cylinder? oh and GET A DAMN HELMS MANUAL you should have one already if you're asking this.
but if u must know, on a y7 motor...
main bearing cap bolts- step 1 - 15ft/lb
step 2 - 38ft/lb
oil pickup tube bolts - 17ft/lb
oil pan bolts - 9ft/lb
good luck
Old Apr 28, 2006 | 08:24 AM
Default Re: i spun a rod bearing and need some help.. (tractiondeprived)
are you aware of the torque pattern you need to follow for the girdle?
Old Apr 28, 2006 | 08:32 AM
Vintech's Avatar
Get a Helms and get to reading
Old Apr 28, 2006 | 04:37 PM
eklum's Avatar
um how do i take off the oil pan do i pry it off?..
i got all the bolts off midsection off clutch dustplate off..
Old Apr 28, 2006 | 04:50 PM
DaveSi677's Avatar
Default Re: (klum)
like mentioned many time above get a <U>HELMS</U>. It's your best friend.
Dave
Old Apr 28, 2006 | 05:09 PM
strictly.business's Avatar
Banned
Default Re: (klum)
wow..put everything back on that youve taken off. call a tow truck or tow it to a shop. if you cant get the oil pan off, youre going to cause more damage<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klum &raquo;</TD></TR><TR><TD CLASS="quote">um how do i take off the oil pan do i pry it off?..
i got all the bolts off midsection off clutch dustplate off..</TD></TR></TABLE> than just a spun rod bearing.
Old Apr 28, 2006 | 06:19 PM
eXcelonTypeR's Avatar
Default Re: (strictly.business)
I agree with everyone on here get a damn HELMS and take the car to the shop it might cost money but its cheaper then buying all new internals or motor (in some cases)
Old Apr 28, 2006 | 06:34 PM
Default Re: (klum)
you dont need to replace that rod bearing. take it to a mechanic. you're only going to do more harm than good. tell me where the thrust washers go and MAYBE you'll be ok figuring it out. if you cant answer that dont touch inside your motor.
Old Apr 29, 2006 | 09:35 AM
eklum's Avatar
its just the bearings..
http://img133.imageshack.us/im...n.jpg
my uncles a mechanic im gonna bring him over when i put everything back togather... the crank looks fine and undamaged from what i can see.. its still smooth ..ill make sure to let you guys know how it goes.
Old Apr 29, 2006 | 10:35 AM
rextec's Avatar
i did this on my y7 (replaced one rod bearing) and it still knocked afterwards because the big end of the rod was warped from all the heat. i did it for ***** and giggles cause i already had another motor for it.
Old Apr 29, 2006 | 11:51 AM
eklum's Avatar
yeah i just need to fix this until i have my motor built
Old Apr 29, 2006 | 01:54 PM
themorphious's Avatar
Default Re: (klum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klum &raquo;</TD></TR><TR><TD CLASS="quote">yeah i just need to fix this until i have my motor built</TD></TR></TABLE>
ok.....if you plan on fixing this motor....and then build the same motor you're fixing......then it's not gonna work....bceasue you cant "temporarily" fix spun bearings...if you think that's how it's gonna go....then get out the jb weld i guess.....to put your cylinder walls back together.......lol!!!!
Old Apr 29, 2006 | 02:19 PM
eklum's Avatar
... how can you not replace a bearing? those are there to be replaced
thats why that wears down instead of your crank
Old Apr 30, 2006 | 07:13 AM
Default Re: (themorphious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themorphious &raquo;</TD></TR><TR><TD CLASS="quote">ok.....if you plan on fixing this motor....and then build the same motor you're fixing......then it's not gonna work....bceasue you cant "temporarily" fix spun bearings...if you think that's how it's gonna go....then get out the jb weld i guess.....to put your cylinder walls back together.......lol!!!! </TD></TR></TABLE>
i dont understand your logic behind a spun bearing causing damage to the cylinder walls. so long as the piston rings remain intact then the cylinder walls will be perfectly fine. the only thing i would worry about is that bearing looked pretty bad, you might want to take that crank to a machine shop and have them take a look at it. i've had a bearing spin so badly before that it actually welded the rod bearing to the crank itself. i had to cut it off to get the rod out. which sucks because b16 cranks are a tad more expensive than one for your y7. i dunno if you're anywhere close to the chattanooga, tn area but if so i have a couple extra y7/y8 cranks laying around. i'd let em go for next to nothing, just get that **** outta my garage its taking up space. i could probably ship one to you, just using a lot of peanuts or whatever to make sure no stress is put on it so it won't warp, but that **** is heavy and shipping would probably be quite a bit. let me know.
Old Apr 30, 2006 | 07:40 AM
bluevic99's Avatar
Goto clubsi.com and they have the honda manual in the tech support section that you can download and use.
Quetzolcotl
Feb 17, 2017 02:50 AM
coot_er
Nov 10, 2009 09:25 PM
igorka_91
13
Jul 5, 2009 12:29 PM
sixtodc4
Jan 20, 2008 09:33 AM
JaHnAbOi
12
Jun 22, 2006 11:00 PM
