just fired the h23vtec up for the 1st time
Old Apr 28, 2006 | 06:58 AM
Lude@Heart's Avatar
Default just fired the h23vtec up for the 1st time
and everything went good. runs smooth, and no hesitations.
Its goin in for tuning either tnight or tommorrow and ill let yall know how it went.
Setup:
H22a1 Block
H23a1 Crank
H23a1 Rods
H22 Type s Pistons .25 over
H22a4 Head
ARP Headbolts
All oem gaskets
P28 on Crome Pro Tune via Wideband.
CR 12.2:1
Now ill need a nice header to accomodate that.
Old Apr 28, 2006 | 07:09 AM
Ross 2.0's Avatar
In a Junkyard near you.
pics?
Old Apr 28, 2006 | 07:18 AM
-DesTiNy-'s Avatar
I'm a Jackass
Default Re: (MooGoCow3)
pics would be nice
Old Apr 28, 2006 | 07:24 AM
Archidictus's Avatar
Unceasing Measure
Default Re: just fired the h23vtec up for the 1st time (Lude@Heart)
Is this in a Civic? Did you mean to post this good news in this forum or were you aiming for some other one and just missed
Congrats, either way
Old Apr 28, 2006 | 08:28 AM
Lude@Heart's Avatar
http://s30.photobucket.com/alb...c%20S/
ill take pix of it in the car tday
yeah its in a eg
i figured it post it, so some ppl can see that its a possible motor to build. and cause i like to show my work lol
EDIT: found pix of it previously in the car b4 i pulled it back out and replaced clutch.
http://s30.photobucket.com/alb...0swap/
that was goin from the H23 to the H22 Head
Modified by Lude@Heart at 5:41 PM 4/28/2006
Old Apr 28, 2006 | 09:11 AM
Spracer03's Avatar
what color is your car?
Old Apr 28, 2006 | 09:34 AM
Lude@Heart's Avatar
stock 92 hatch SI color
Old Apr 28, 2006 | 09:49 AM
DJ_SaNdOz's Avatar
Default Re: (Lude@Heart)
who did the hone work on the cylinders? Were they able to follow the actual Honda procedure, or did you get the block sleeved?
Old Apr 28, 2006 | 10:18 AM
Lude@Heart's Avatar
local machineshop, yeah they followed the honda procedure, and i had my friend go there 1st so i could see if they do a good job, and it worked for him. the main reason that most shops fk it up is cause they dont have a machine that can hone at 45-50rpm, most hone at 150, and thats way too fast.
Old Apr 28, 2006 | 10:20 AM
schardbody's Avatar
I heart your BAY
Old Apr 29, 2006 | 11:40 AM
Lude@Heart's Avatar
still waiting for tuning, took it for a drive tday, but due to the lightweight flywheel it stalls sometimes when i let off the gas in neutral. tuning should fix that tho.
Old Apr 29, 2006 | 11:53 AM
keemosaki's Avatar
wow NICE! by the way the color is captiva blue pearl... i miss that color....
Old Apr 29, 2006 | 12:12 PM
UberJDMef8's Avatar
interesting motor choice. are you going to have it dyno'ed? if so whut kind of numbers are you hoping to get?
Old Apr 29, 2006 | 01:55 PM
Lude@Heart's Avatar
ill dyno it one day when i got money again lol
im hoping to be in the 190 whp area
Old Apr 30, 2006 | 11:36 AM
UberJDMef8's Avatar
good luck with the rest of your build. cant wait to see some number
Old Apr 30, 2006 | 06:10 PM
Lude@Heart's Avatar
just got done tuning it, and whoa is it a fun ride. Had some pinging issues at 1st due to a pinhole in the vacume line to the map sensor, fixed that and it was all good from then. timing is only a little higher then stock settings cause im only running 93, i might have to upgrade to methanol injecton for added timing cause im detonating if we add timing any more. other then that its fun, im gonna take it easy on it for the next we days till all the parts are worn in good, and i gtta keep my eyes on a vtec solenoid gasket leak thats VERY slow, ill post some random tuning videos as soon as i can find my cable to hookup the camera. till then, keep checking back once in a while ill b around.
Old May 1, 2006 | 12:40 PM
ilikebigbutts's Avatar
nice ****, i want an eg
ILBB
Old May 1, 2006 | 02:31 PM
The_Head's Avatar
It's very similar to my old setup. It was great fun.
Old May 1, 2006 | 03:34 PM
dxhatch92's Avatar
what do those 2 big hoses coming out of your valve cover do? nice swap btw
Old May 1, 2006 | 04:10 PM
92hondalude's Avatar
Default Re: (dxhatch92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">It's very similar to my old setup. It was great fun.
what IM is that
great build
Old May 2, 2006 | 07:24 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude@Heart &raquo;</TD></TR><TR><TD CLASS="quote">just got done tuning it, and whoa is it a fun ride. Had some pinging issues at 1st due to a pinhole in the vacume line to the map sensor, fixed that and it was all good from then. timing is only a little higher then stock settings cause im only running 93, i might have to upgrade to methanol injecton for added timing cause im detonating if we add timing any more. other then that its fun, im gonna take it easy on it for the next we days till all the parts are worn in good, and i gtta keep my eyes on a vtec solenoid gasket leak thats VERY slow, ill post some random tuning videos as soon as i can find my cable to hookup the camera. till then, keep checking back once in a while ill b around.</TD></TR></TABLE>
Methanol injection? 12.2 on 93octane isn't that bad. There are numerous people in cali doing it on 91 with a similar CR.
Old May 2, 2006 | 08:21 AM
Lude@Heart's Avatar
well i cant advance timing anymore then stock, the AFs are perfect and im still pinging.
Old May 2, 2006 | 08:50 AM
Marcpb443's Avatar
Looks nice good swap.
Old May 2, 2006 | 09:17 AM
siregcivic's Avatar
Default Re: just fired the h23vtec up for the 1st time (Marcpb443)
you dont need to advance your timing.. you have enough compression for the low end.. i would suggest maybe retarding your timing a degree or 2
Old May 2, 2006 | 09:24 AM
Turbogixxer's Avatar
Default Re: just fired the h23vtec up for the 1st time (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to advance your timing.. you have enough compression for the low end.. i would suggest maybe retarding your timing a degree or 2 </TD></TR></TABLE>
You can ran less timing and make great power. Running less timing and making the same power as you were before (for arguments sake), the motor is more efficient. Adding timing is not always to make power.
