to much air pressure? fix?
Old Apr 28, 2006 | 06:25 AM
stemiched's Avatar
Default to much air pressure? fix?
I have a 91 crx and there was an oil leak, just figured out where the oil leack is. There is a lot of air pressure coming out of the top oil cap. is there any way to fix this? air pressure let out valve or something? i was told my a mechanic who hates imports that my engine is dieing... is this true or sould it still run for some time?
Modified by stemiched at 6:57 AM 5/3/2006
Old May 3, 2006 | 06:01 AM
stemiched's Avatar
Default Re: to much air pressure? fix? (stemiched)
bump
Old May 3, 2006 | 08:07 AM
jlicrx's Avatar
could be blow-by around the rings, but could also be from plugged PCV valve - have you changed the PCV valve lately? is the breather tube on the valve cover open?
Old May 3, 2006 | 09:05 AM
I_eat_Rice's Avatar
Default Re: to much air pressure? fix? (jlicrx)
if smog controlls dont matter to you just go to walmart or autozone and buy a 12mm air breather fiilter and pop that in place of your pcv.
Old May 3, 2006 | 11:39 AM
stemiched's Avatar
Default Re: to much air pressure? fix? (I_eat_Rice)
okay wow... im not smart... i have no clue what you just sead...
Old May 3, 2006 | 12:14 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I_eat_Rice &raquo;</TD></TR><TR><TD CLASS="quote">if smog controlls dont matter to you just go to walmart or autozone and buy a 12mm air breather fiilter and pop that in place of your pcv. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stemiched &raquo;</TD></TR><TR><TD CLASS="quote">okay wow... im not smart... i have no clue what you just sead... </TD></TR></TABLE>
He made no sense , dont worry about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">could be blow-by around the rings, but could also be from plugged PCV valve - have you changed the PCV valve lately? is the breather tube on the valve cover open?</TD></TR></TABLE>
pretty much what i would have said.
Looneytunerz
Nov 2, 2012 12:57 PM
pmp
10
Jan 8, 2012 03:59 PM
scspeed
May 25, 2010 11:04 AM
4gencivicef9
May 21, 2007 06:30 PM
DC 2
Apr 15, 2004 02:51 PM
