brake light warning light staying on
im checking the wiring loom for faults as i downloaded the diagrams ill keep you all posted
all that peugeot training come in good for something
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Weather Man »</TD></TR><TR><TD CLASS="quote">That means that one of your brake lights aren't working. Have someone press the pedal and figure out which one doesn't work.
I have had this same problem and i have replace ALL of my bulbs because it pissed me off so much...still no luck though!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod »</TD></TR><TR><TD CLASS="quote">There is also a fluid level sensor in the brake master cylinder resivoir.</TD></TR></TABLE>
don't forget that one.
i have checked all the globes and have unpluged the level sensor but this made no difference i will ohms check the level sensor next and keep you all up todate
the fluid level was allright so no point in topping up the fluid disconnected the sensor as i thought that the sensor may be faulty
JSPECHB
May 25, 2004 04:25 PM
