clutch and fly wheel
Old Apr 27, 2006 | 09:40 PM
redhanyo's Avatar
Default clutch and fly wheel
As im building, well buying parts for my car, im trying to also learn.
So, what are the benefits of replacing the clutch and flywheel? any cons?
What type of clutch and flywheel options?
When the clutch is changed, what other things should be changed, if any?
i have a b16 del sol, if that matters. thanks
Old Apr 27, 2006 | 09:49 PM
all-mtr-teg's Avatar
Default Re: clutch and fly wheel (redhanyo)
get a act streetlite flywheel (11lb.) if your a daily driver, helps rev up quicker, getting you into the power band sooner. A good clutch, such as act, clutch net will help get your horsepower to the wheels. Get an organic disk or 6 puck if you don't mind the heavier pedal effort. I got act streetlite flywheel and clutch net 6 puck in an all motor daily driven gsr, engages fairly smooth, but gets up to power band a lot sooner w/ lighter flywheel.
Old Apr 27, 2006 | 09:52 PM
redhanyo's Avatar
Default Re: clutch and fly wheel (all-mtr-teg)
any drawbacks to a lighter flywheel? do you know how much lighter than stock?
when u say hevier pedal, do you mean harder to push down?
Old Apr 27, 2006 | 10:00 PM
some people go overboard and get the prolite flywheels, only like 7 or 8 lbs, depending on brand, stock is I think 18 lbs. Stock type r is 14 lbs. The 11 lbs is great for daily driving, you might lose a bit of torque off the line due to a loss of inertia, but the horsepower makes up for it. the prolite flywheels are good for pure drag, my tuner told me to stay away from the prolite if i was gonna keep it a daily driver, he owns a JDM2 in central cali, so I take his advice.
colbynorwood
Transmission & Drivetrain
Mar 16, 2011 06:42 PM
Solipsist
Dec 6, 2002 11:49 AM
lbz34
Mar 17, 2002 06:32 PM
tinter
Jul 21, 2001 04:23 PM
