THROTTLE BODY question!
Old Apr 27, 2006 | 09:00 PM
-DesTiNy-'s Avatar
I'm a Jackass
Default THROTTLE BODY question! (pics inside)
sup guys, I just got done doing a swap for one of my homeboys civic lastnight.. and everything went well... only small problem was that it is bogging on me! it bogs in the idle and lower rpms like 1or2... also if i let go of the gas in 1/2 gear it bogs..
I checked the 02 censor and it was fine, I replaced the sparkplugs and sparkplugs wires (whice needed to be changed anyways) I already checked the dissy and moved it and all that... and its still bogging.... timing is good, blets are new..
by the way I installed a D16y8 and i'm using a d16z6 Throttle Body... and i'm pretty sure thats the problem right there...
okay on to my question..
will s skunk2 TB fit on a stock y8 manny?
if so what size should i get? 60MM? 66MM? 68MM? 70MM ?
mods are I/H/E
Modified by -DesTiNy- at 11:33 AM 4/28/2006
Modified by -DesTiNy- at 12:37 PM 4/29/2006
Old Apr 27, 2006 | 09:10 PM
-DesTiNy-'s Avatar
I'm a Jackass
Default Re: THROTTLE BODY question! (-DesTiNy-)
comon h-t
i already Searched
Old Apr 27, 2006 | 09:31 PM
-DesTiNy-'s Avatar
I'm a Jackass
Old Apr 27, 2006 | 10:38 PM
1cleangsr's Avatar
Just wondering, is it throwing any codes?
Old Apr 28, 2006 | 07:13 AM
-DesTiNy-'s Avatar
I'm a Jackass
Default Re: THROTTLE BODY question! (1cleangsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1cleangsr &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering, is it throwing any codes? </TD></TR></TABLE>
nope,
omg, comon h-t HELP ME!
Old Apr 28, 2006 | 09:31 AM
pdiggitydogg's Avatar
Perhaps a dumb question, but have you tried adjusting the throttle cable and idle adjust screw?
Old Apr 28, 2006 | 10:32 AM
-DesTiNy-'s Avatar
I'm a Jackass
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Perhaps a dumb question, but have you tried adjusting the throttle cable and idle adjust screw?</TD></TR></TABLE>
where is the idle adjust screw???????????!!!!!!!!!!!! wtf! I did this whole swap... everything going great! you think its a leak??
Old Apr 28, 2006 | 10:38 AM
turboman's Avatar
didn't see what kinda motor you put these on
Old Apr 28, 2006 | 10:55 AM
-DesTiNy-'s Avatar
I'm a Jackass
d16y8 with y8 manny
Old Apr 28, 2006 | 11:41 AM
Circled in yellow, top of the TB. (I know its not the best picture, but you can see that its a screw head)
Depending on how "tight" it is, determines how much air is let in, at idle. Just open it up a bit.
Old Apr 28, 2006 | 02:49 PM
jdmeg9's Avatar
that motor looks tiny in there
Old Apr 28, 2006 | 06:12 PM
-DesTiNy-'s Avatar
I'm a Jackass
thx!
hmmm... the more i open it the worse it bogs ?
wtf?!!! i dunno what to do!! i prolly gunna get a whole new TB
Old Apr 28, 2006 | 06:17 PM
Syndacate's Avatar
try turnign it the other way then, it's called tuning, see if u can get it to a point where it seems fine :-\
Old Apr 28, 2006 | 06:21 PM
macrohard's Avatar
Have you tried cleaning the IAVC? Had the same problem and mine was dirty as hell. After cleaning motor runs like a champ.
Old Apr 28, 2006 | 07:13 PM
-DesTiNy-'s Avatar
I'm a Jackass
Default Re: THROTTLE BODY question! (macrohard)
IAVC ?
you mean inside the dizzy ?
Old Apr 28, 2006 | 07:17 PM
jdmeg9's Avatar
the iacv is on the backside of the intake manifold behind the throttle body
Old Apr 28, 2006 | 07:41 PM
The iacv isnt going to stop bogging.
If turning the screw one way makes it bog worse, turn it the opposite way.
If it just wont work, you can always buy my y8 tb
Old Apr 29, 2006 | 11:36 AM
-DesTiNy-'s Avatar
I'm a Jackass
i'm gunna get a Y8 TB today, i'll post for an update
Sixx23
Feb 12, 2014 02:38 PM
twentytwocpb
Mar 20, 2008 10:47 AM
kemo909
Feb 14, 2007 08:10 PM
Jdmbsixteen
17
Feb 18, 2004 07:54 PM
