highest CR that anyone has passed smog with?
What does it matter?
You're not going to run anything over 12:1 anyway.
Correct me if I'm wrong, but as long as a motor is tuned properly and all emissions equipment is functioning properly, compression doesn't mean jack.
edit: Maybe NOx will increase, as they goes up with cylinder temps if I'm not mistaken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">What does it matter?
edit: Maybe NOx will increase, as they goes up with cylinder temps if I'm not mistaken.</TD></TR></TABLE>
correcto
correcto
so i could technically pass with an 11:1 CR? but if nox goes up as temp goes up, wouldnt i be screwed if the engine is hot when i get it smogged?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">you are over thinking</TD></TR></TABLE>
lol...
you're right though.. but i am still confused... so is the bottom line that it would technically pass?
lol...
One of the shops that I worked for did emission testing. I've seen MANY smaller motors come in running like ****, that passed by a mile. Fortunately, I passed twice
. I'm 99% sure that as long as it's tuned properly and all emissions equip is functioning, you'll pass with flying colors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wazup »</TD></TR><TR><TD CLASS="quote">so i could technically pass with an 11:1 CR? but if nox goes up as temp goes up, wouldnt i be screwed if the engine is hot when i get it smogged?</TD></TR></TABLE>
You want the cat to be nice and hot when you test. The highest compression I passed smog with, was just under 12:1.
jaystation
Sep 13, 2005 03:39 PM
