SMOG QUESTION
i have a 88 dx swapped in a d16z6...im going to smog it next month but i need to swap out the aem intake...do i put on the stock 88-91 intake or the stock 92-95 del sol/civic ex/si intake??? or are all d-series stock intake the same???
I thought aem intakes were smog legal. Well if you ahve the stock intake try it, if it doesnt fit or work, its obviously gonna be the d16z6 intake. and if you dont have any intake, just buy the d16z6 intake.
i would use the crx/civic Si intake tube and air box.
about using the z6 intake tube and air box... the battery will be in the way.
and you wont be able to use the stock DX intake because of the top mount throttle body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N »</TD></TR><TR><TD CLASS="quote">i would use the crx/civic Si intake tube and air box.
and you wont be able to use the stock DX intake because of the top mount throttle body.</TD></TR></TABLE>
thats what i was thinkng...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N »</TD></TR><TR><TD CLASS="quote">you wont be able to use the stock DX intake because of the top mount throttle body.</TD></TR></TABLE>
from the 92-95 or the ef???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N »</TD></TR><TR><TD CLASS="quote">i ment the EF.</TD></TR></TABLE>
so i cant use the 88-91 civic dx but i can use the 88-91 crx/civic si one???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La-quiete »</TD></TR><TR><TD CLASS="quote">I thought aem intakes were smog legal. </TD></TR></TABLE>
are they??? if anyone knows please let me know....thanks
during the visual part of the test what do they look for?? im worried about the way my battery is tied down...i dont have a battery tie down and just used rope to tie it down...im also worried about my wires showing from the obd0 to obd1 conversion...are these important during the visual at a TEST ONLY station???
i dont know what test only do you go to. but mine here they dont even look at the ECU. they just look under my hood and make sure all the vital equipment is there and hooked up.
i even removed my throttle body dash pot and i the guy didnt even care to notice. and i pasted smog haha.
stop being a chicken and go do it already. just go there and ask if they give free pre-test. usualy with a pre-test they can see if you will pass the acutal smog.
and if they do charge for pre test its only 25 bucks and if you fail the it wont be recorded into dmv.
man it up.
man it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N »</TD></TR><TR><TD CLASS="quote">i dont know what test only do you go to. but mine here they dont even look at the ECU. they just look under my hood and make sure all the vital equipment is there and hooked up.
man it up.</TD></TR></TABLE>
im about to do it this weekend...found a place if i fail free retest...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdA1T6CzH6 »</TD></TR><TR><TD CLASS="quote">im about to do it this weekend...found a place if i fail free retest...</TD></TR></TABLE> Most spots are like that nowadays......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdA1T6CzH6 »</TD></TR><TR><TD CLASS="quote">battery is being held down by rope will the guy care??? </TD></TR></TABLE>
No, they look for vital emission sensors and equipment. things like O2, evap, egr (which we dont have), cat, and stuff like that, if he gives you **** about the battery, tell him to f off.
It depends who the person is doing the smog If he is a honda guy he should know that your intake is legal. Does it say AEM on it. then tell him to check the CARB list.
As for the obd0/1 conversion try to hide the wires or wrap them in electrical tape. Make it look like it is stock. He might not even figure it out that it is a Z6 unless he checks every vacuum line to the manifold. If he doesn't see it he can't fail you for it.(We do check for electrical connections as part of the visual)
Also if the motor does not match the emissions label remove the label from the hood. That way he has to go from the book and the book is not always correct.
Some helpful hints from a friendly test only smog tech.
As long as all the emissions equipment are installed and functional there shouldn't be any issues. Make sure that your engine bay looks like OEM. Use electrical tape to hide any loose wires that don't supposed to be there.
Originally Posted by jpnucrx
I have a Skunk 2 IM...which they just made not CARB legal...
Originally Posted by vtakvtrak
hazw8st is da ****, he knows his smog.
Originally Posted by SleeperDC2_ZzZ
go to hazw8st for help on smog.
Originally Posted by Go_HIN
hazw8st definitely hooked it up. I tipped him good.
Originally Posted by efboy
hazw8st got it all straighten out ! anybody need help with smogging ur jdm swaps hit up hazw8st !
Originally Posted by MikeEM1
hazw8st took care of me too! hit him up people.
Originally Posted by xx89civicracer89xx
good joke hazw8st.
Originally Posted by Lauj87
hazw8st knows how to do it the legal way.
Originally Posted by DAb20vtec
hazw8st hooked me up! smog exempt is the ****!
Originally Posted by Takeoff
email hazw8st he can really help u with this. He smogged and registered my 240sx when no one else could.
Originally Posted by NightRider-gsR
Add me to one of hazw8st's SMOG list.
Most definitely will refer my peoples to him!! Great guy to work with!
He should be HT's SMOG go to guy! NO JOKE.
RHD, swaps, turbo...As long as your car ain't a joke, he will hook you up!
Originally Posted by christhereefer
I'll vouch for Hazw8st. He's legit as can be. no more ref. tickets again and no more smog checks.
Originally Posted by rsxk24
hazw8st is legit, give him all your money. he can legally smog a k24 turbo with no cat and open exhaust!
Originally Posted by code47mastermind
For all of you wondering if hazw8st is legit. He totally is. He helped me out. My tags and registration are now up to date and legal. Not only that, but he is also a real good guy.
Modified by hazw8st at 9:09 AM 12/30/2006
i have a 90 crx si w/b16a and cheap ebay intake and i hade to go to a test only and they passed mine.and i had my nitrous hooked up, w/ the line ran to the intake and everything, so u never know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtakvtrak »</TD></TR><TR><TD CLASS="quote">hazw8st is da ****, he knows his smog.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperDC2_ZzZ »</TD></TR><TR><TD CLASS="quote">go to hazw8st for help on smog. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Go_HIN »</TD></TR><TR><TD CLASS="quote"> hazw8st definitely hooked it up. I tipped him good. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efboy »</TD></TR><TR><TD CLASS="quote">
hazw8st got it all straighten out ! anybody need help with smogging ur jdm swaps hit up hazw8st !</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeEM1 »</TD></TR><TR><TD CLASS="quote">hazw8st took care of me too! hit him up people.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xx89civicracer89xx »</TD></TR><TR><TD CLASS="quote">good joke hazw8st.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 »</TD></TR><TR><TD CLASS="quote">hazw8st knows how to do it the legal way.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAb20vtec »</TD></TR><TR><TD CLASS="quote">hazw8st hooked me up! smog exempt is the ****! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takeoff »</TD></TR><TR><TD CLASS="quote">email hazw8st he can really help u with this. He smogged and registered my 240sx when no one else could. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">Add me to one of hazw8st's SMOG list.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christhereefer »</TD></TR><TR><TD CLASS="quote">I'll vouch for Hazw8st. He's legit as can be. no more ref. tickets again and no more smog checks. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxk24 »</TD></TR><TR><TD CLASS="quote">hazw8st is legit, give him all your money. he can legally smog a k24 turbo with no cat and open exhaust! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by code47mastermind »</TD></TR><TR><TD CLASS="quote">For all of you wondering if hazw8st is legit. He totally is. He helped me out. My tags and registration are now up to date and legal. Not only that, but he is also a real good guy.
Modified by hazw8st at 9:06 AM 12/30/2006
i just brought it in for test only today and the guy said he couldnt do it because it was a different motor...he said everything was fine with it..the header, wiring, intake.. was all good but he couldnt do it because it was a different motor....he knew his stuff...daym it...SAN BRUNO SMOG TEST ONLY!! anybody else know where i can go???
...will this make me fail?....My date for emissions is in 2 weeks....what should i do?
