JDM Headlights pass state inspection????
Old Apr 27, 2006 | 05:02 PM
bburtonsk8r2's Avatar
Default JDM Headlights pass state inspection????
hey, i just got my car inspected, and failed 1. for having hid headlight bulbs, and 2 for having a broken bucket, sooo i was going to buy some jdm headlights, but wasnt sure if they would pass state inspection, because they are not factory bulbs anyone have any idea??? im pretty sure ill be alright, just asking.
Old Apr 27, 2006 | 05:22 PM
prelude1897's Avatar
Default Re: JDM Headlights pass state inspection???? (bburtonsk8r2)
Why not just put your halogens back in and get it inspected, then just put your HIDs back in whenever you pass
Old Apr 27, 2006 | 06:10 PM
ShinobiLude's Avatar
Default Re: JDM Headlights pass state inspection???? (prelude1897)
Are you asking if because its a black one peice light it will pass? They most def will...the only thing i noticed difference about USDM lights is....that they dont have those 3 nipples on the glass/plastic. I never figured out what those nipples do. If you look at every US headlight on a car...they always have 3 nipples. Besides that....well they pass in Delaware.
Old Apr 27, 2006 | 06:11 PM
AndyD's Avatar
They should pass without any problem as long as they are crack-free and have DOT approved light bulbs.
Old Apr 27, 2006 | 06:13 PM
AndyD's Avatar
Default Re: JDM Headlights pass state inspection???? (ShinobiLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinobiLude &raquo;</TD></TR><TR><TD CLASS="quote">If you look at every US headlight on a car...they always have 3 nipples. Besides that....well they pass in Delaware. </TD></TR></TABLE>
I always wondered about that too. The ONLY reason I could come up with was the nipples somehow add strength to the glass surface.
Old Apr 27, 2006 | 07:14 PM
Silver Surfer's Avatar
technically the jdm lights could fail because they have no reflectors
all usdm headlights and taillights have reflectors in them
but i am pretty sure the prelude gets covered by the reflectors in our turn signals even if the headlights don't have them.
Old Apr 27, 2006 | 07:36 PM
i have a broken headlight adjuster, from an accident from previous owner, a new or used headlight is almost as much as jdm headlights, i just bought a set for 195 shipped. hopefully i can pass with h4 headlight bulbs, should be alright
Old Apr 27, 2006 | 08:07 PM
helicopter201's Avatar
Default Re: JDM Headlights pass state inspection???? (AndyD)
Nipples are from the plastic casting process. The jdm ones do not have them because they are glass and are not poured into a mold. As far as strength is concerned...it might be a LITTLE bit stronger than the rest of the face but really inconsequential.
Old Apr 27, 2006 | 08:14 PM
cfran55's Avatar
Default Re: JDM Headlights pass state inspection???? (helicopter201)
how do they check for this
mine has a blue bulb that cracked inside and so you can see a tint of blue in the passenger side
everyone is like eww why do you have blue headlights lmao
also i got maggots in my rear taillights wtf
Old Apr 27, 2006 | 08:20 PM
JBLude01's Avatar
The three little nipples are used for headlight aiming. I'm a licensed PA safety inspector, and i would pass the JDM headlights, plus they look so much better. As long as the headlights have adjustment they should pass.
Old Apr 27, 2006 | 09:55 PM
bboixtc's Avatar
Default Re: JDM Headlights pass state inspection???? (JBLude01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helicopter201 &raquo;</TD></TR><TR><TD CLASS="quote">Nipples are from the plastic casting process. The jdm ones do not have them because they are glass and are not poured into a mold. As far as strength is concerned...it might be a LITTLE bit stronger than the rest of the face but really inconsequential.</TD></TR></TABLE>
i'm sure that it is. however. the USDM lenses are glass. and the JDM's are made of plastic. and its the USDM GLASS lenses that have nipples. so your just all backwards.
Old Apr 28, 2006 | 07:26 AM
Default Re: JDM Headlights pass state inspection???? (bboixtc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboixtc &raquo;</TD></TR><TR><TD CLASS="quote">
i'm sure that it is. however. the USDM lenses are glass. and the JDM's are made of plastic. and its the USDM GLASS lenses that have nipples. so your just all backwards. </TD></TR></TABLE>
He is right sir.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBLude01 &raquo;</TD></TR><TR><TD CLASS="quote">The three little nipples are used for headlight aiming. I'm a licensed PA safety inspector, and i would pass the JDM headlights, plus they look so much better. As long as the headlights have adjustment they should pass. </TD></TR></TABLE>
Thanks for the answer! I would be pissed if i had to swap my headlights at the DMV inspection because they dont have nipples. I mean seriously.
Old Apr 30, 2006 | 06:55 PM
thanks guys, good lookin, jdms def look better, i just didnt want to buy them quite yet but its all good. the hid's are way brighter then just blue bulbs, and they will be going right in after inspection. i dont want my headlights to have nipples anyways
06BlackSi #45
Honda Civic (2006 - 2015)
Jun 14, 2008 08:24 PM
PatrickGSR94
Lighting
11
Jan 3, 2008 12:30 PM
JDMStilez
Dec 27, 2004 12:07 AM
GqchYnAbOy
Sep 25, 2003 12:10 AM
