How much heavier IS a 4dr over a hatchback?
Old Apr 27, 2006 | 04:51 PM
Xenobi's Avatar
Default How much heavier IS a 4dr over a hatchback?
I'm running a B16A2 in a 4dr (92') vs a D16Z6 in a hb (92'). I took the launch, roared ahead in second gear, and then he gradually pulled through third, fourth, and the first part of fifth, before catching me at the line.
I should have pulled on him the whole race.....whats up with that? Is the 4 door really that much heavier?
Old Apr 27, 2006 | 04:55 PM
E46Kid's Avatar
you just got owned by sohc vtec! He either has mods and your stock or either hes gutted to the max More info
Old Apr 27, 2006 | 05:04 PM
aquabob89's Avatar
* B A N N E D *
Default Re: (EkSi)
ive beat a gsr integra.
with a couple hundred thousand miles.....
....d15b7/z6 dd
Xenobi's Avatar
Default Re: (EkSi)
Its my best friend....I/E with a fuel tuner (hb) vs intake and open header (4dr). Both motors stock, and if it helps any, my tires are probably stickier...both cars completely assembled, nothing taken out.
Old Apr 27, 2006 | 05:05 PM
db8gsr_teg's Avatar
maybe he was a better driver than you
Old Apr 27, 2006 | 05:06 PM
Xenobi's Avatar
Default Re: (db8gsr_teg)
I highly doubt it...but then again, I was going by ear...no tach yet....
Didn't hit the rev limiter once and ran it most of the way through vtec...hell, he even missed third gear.
Old Apr 27, 2006 | 05:07 PM
tatmark1's Avatar
i was about to say that
Old Apr 27, 2006 | 05:55 PM
longuyen88's Avatar
if anything, you should've lost on the launch because you're heavier, and b16's are just like d16s below 5k anyways. After vtec, that's a different story. I don't know about your situation tho.
Old Apr 27, 2006 | 06:00 PM
cambopheonix56's Avatar
Default Re: (Xenobi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xenobi &raquo;</TD></TR><TR><TD CLASS="quote">I highly doubt it...but then again, I was going by ear...no tach yet....
Didn't hit the rev limiter once and ran it most of the way through vtec...hell, he even missed third gear.</TD></TR></TABLE>
So you could have been shifting at like 7500? Theres your problem, I bet your shifts were waaaaaaayy early.
Old Apr 27, 2006 | 06:48 PM
E46Kid's Avatar
Hand over the keys to the teg and ill take him
Old Apr 27, 2006 | 06:52 PM
Xenobi's Avatar
Nah, there was no way I was shifting below 8....what does it redline at anyway?
Old Apr 27, 2006 | 06:58 PM
db8gsr_teg's Avatar
get a damn tachmeter then you will be good
nickels
Apr 1, 2004 07:27 PM
whitedaze
Aug 28, 2001 09:22 PM
