Questions about cams/turbo
Old Apr 27, 2006 | 03:38 PM
Urban_Legend's Avatar
Default Questions about cams/turbo
I may have some money left and am hoping to get stage 1 cams purchased along with my cam gears and stuff and i got to thinking about future plans i had and came up with kinda a little delema.
So say i do have some extra money to purchase the cams and get them with the cam gears dyno tuned before june8 but in the next yr or 2 depending on how other projects and money go hope to and really plan on going with a mild stage one turbo. So the question i have is that is it really worth getting the stage one cams and having them dyno tuned or should i just save up for the turbo? Now remember i am running a automatic (becuz i planned on doing something different and putting a turbo on a auto and trying to get a lot of power out of it), but i think ive been convinced enough to switch over to a manual.
I am also running a H23 and stuck with it becuz i had heard it was better for turbo so i planned on keeping it and see how much i could really get out of it compared to everyones fav H22 turbo. Unless i can get really talked into a H22 i really dont plan on switching over unless there gunna be some huge problem im gunna run into that i wouldnt with the H22; besides the shitty sleaves.
This all said as long as compression test comes back good. If not and its a cheap fix then i may continue otherwise if need be ill get another engine and swap over to the JDM H22
Old May 4, 2006 | 10:44 PM
Default Re: Questions about cams/turbo (Urban_Legend)
guess no one has an opion on if its worth or ok to get stage 1 cams and then go turbo in a yr or 2. Or if i should just go for the turbo then cams after i have the turbo.
Old May 5, 2006 | 04:21 AM
The Weather Man's Avatar
Crower has some stage 2 turbo cams that i hear are pretty decent. Let me find the part number........................
The part # is 290-63421T
The "T" is for turbo
The description says "Turbo special design. Short duration = low overlap, high lift for increased power"
Eresuncabron
14
Aug 4, 2004 06:11 AM
OneThirtyEight
May 14, 2002 11:58 AM
PaChiLa Leader
Nov 17, 2001 02:36 PM
