radiator fan problem?
Old Apr 27, 2006 | 01:08 PM
aznryd3r's Avatar
Default radiator fan problem? A/C problem also
This is probably a noob a$$ question. Are both of the radiator fans supposed to be spinning when the car is on but not moving? I just never noticed the fans before. Thanks if anyone can help. feel free to flameee
Modified by aznryd3r at 2:45 PM 4/27/2006
Old Apr 27, 2006 | 01:21 PM
AK94GSR's Avatar
Default Re: radiator fan problem? (aznryd3r)
if u have the a/c on then yes both will be on, but if no a/c then usually not.
the cooling fan should only be on
Old Apr 27, 2006 | 01:44 PM
aznryd3r's Avatar
Default Re: radiator fan problem? (AK94GSR)
damned...just found out my a/c went out...EXPLETIVE the hot weather!!!..anyone have any idea what the problem is? Dont know what it's called but we had to reset the computer or something..(removed the negative charge from the battery and left it off for a while) now the a/c doesnt work
Old Apr 27, 2006 | 01:45 PM
-Gary-'s Avatar
Not true. When the A/C is on, the A/C fan will be on. The Radiator fan cycles as the temperature rises and falls.
hotrider
Feb 7, 2008 11:38 AM
TomIntegraGSR
Jun 10, 2007 06:23 PM
