Aluminum retainers
Hey I just purchsed some pretty nice parts from two people here....one of which was aluminum retainers for whatever reason I thought it said titanium...can anyone shed some light as to what effect these will have with an aggressive camshaft profile?
The right kind of aluminum can be quite strong..but still..ya its the heat issue that concerns me more. Most aluminum has a melting point of 800F or less and warps at much lower temps. Friction + rotational stress & shear stress = heat and torque tear. But try it out and let us know.
If its not from aluminium but from aluminium alloy (we call) dural (Al-Cu4-Mg) or superdural (Al-Cu-Mg1) (hope its the same in english), than its OK. Its better if dural is hard anodized (dont know if its what I mean, we call it elox - its a kind of surface treatment). Than you get retainers with strength of constructional steel (dural has up to 400MPa, superdural has up to 500MPa), twice softer than titanium (2800 kg/m3, titanium has 4500kg/m3) and with hardened surface against abrasive wear.
Im about to have it on my H23 VTEC when it will by done...
there is VERY ot but....
what the hell shifter is that you have in your car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeZ »</TD></TR><TR><TD CLASS="quote">If its not from aluminium but from aluminium alloy (we call) dural (Al-Cu4-Mg) or superdural (Al-Cu-Mg1) (hope its the same in english), than its OK. Its better if dural is hard anodized (dont know if its what I mean, we call it elox - its a kind of surface treatment). Than you get retainers with strength of constructional steel (dural has up to 400MPa, superdural has up to 500MPa), twice softer than titanium (2800 kg/m3, titanium has 4500kg/m3) and with hardened surface against abrasive wear.
Im about to have it on my H23 VTEC when it will by done...</TD></TR></TABLE>
yep, sequential shifter powered by electromagnet
want more pics? </TD></TR></TABLE>
pics
pics
OK guys, Im pleased that you are interested
But let me make independent thread OK? It does not belong here. Ill put in more info,more pics and a small vid
OK?? Ill post it on monday
I know that JG used to make them but they discontinued them in 2000. I have them in my JG head. Everyone upgraded to titanium because it's stronger but to be honest, I hear about titainum reacting with some other metal will cause it to become brittle and break. It seems to me that aluminum would have more flex and save a motor under the same condition.
MugenB16A2
19
Nov 17, 2003 09:55 PM
